Results 1 to 38 of 38
Thread: 89 S13 coupe
    IA Member zachscar's Avatar
    Gainesville, GA
    Default 89 S13 coupe
    So I am running out of time coming up with cash and I'm going to Europe for a year. I'm going to need cereal cash to have fun with so I think I's gonna have to sell my car.
    Chassis:
    early 89 240sx coupe with unknown mileage on the chassis/motor. The tachometer had ~220k miles on it when I bought the car about 2 years ago and it never worked when I had it. When I bought it it had been sitting for a number of years and was in rough shape. I have no idea on accident history, but as with most 240's I imagine it's had at least one. Having said that it doesn't dog track and it aligns just fine. The body work is all done, just needs to be prepped and painted. I plan on doing the remainder of the prep work and possibly priming the whole car.
    I bought an S&W around the dash cage and didn't realize it until a while later so I installed it anyways. The stock dash was not going back in with the SW cage so I made a custom sheet-metal dash that fits in place of the stock one. The VIN was transferred to this custom dash. The door bars and around the dash A-pillar bars have been replaced with much better fitting ones made from 1.75 x .095 DOM tubing.
    Wiring:
    The car was entirely re-wired with a summit universal 18-circuit harness. I pulled out a couple circuits because I didn't need them, but I kept the wires and they will be included. Everything necessary to drive it is wired up and functions properly on the switch panel I made(hi/low wipers, turn signals, electric fan, lights, back up lights, still working on the hazards circuit). The battery was moved to the passenger-side rear seat. The battery is wired to two cut-off switches, one mounted to the passenger side of the cage and the other in the switch panel in the dash. Both are simple key-type cut-off switches. All of the wiring is sheathed in wire-loom and routed with push in zip-tie holders.
    Engine-control:
    The engine is wired up with a Megasquirt II with PCB 3.0 and the megasquirt relay board. The megasquirt wiring is routed the same way as the chassis harness, and both are completely seperate and could be pulled from the car in maybe an hour. The megasquirt is set-up to control the engine as a stand-alone and has a ton of capabilities beyond what its set up for. It's just a matter of researching and implementing it. The system is simple enough and everything seems to be functioning properly with it. I deleted all the emissions equipment in the process.
    Engine:
    The engine is basically stock, I deleted all the emissions equipment from the motor, including the butterfly system right at the head that is vacuum operated normally. It has an e-bay stainless steel header wrapped in header wrap and painted in black hi-temp paint. The exhaust is a home-made 2 1/4" with only a simple muffler at the end(it sounds decent and is relatively quiet). I made a custom aluminum 2.75" intake with some mandrel bent tubing and TIG'ed it together. The radiator is replaced with a cx-racing aluminum radiator from e-bay with dual 12" fans controlled by a switch. It has an oil filter relocation kit on it plumbed to an FC rx-7 oil-cooler which is GIANT.
    Drive-train:
    The flywheel was lightened down to ~16-17 lbs. and the clutch is just an oem replacement with plenty of wear left in it. The drive-shaft is an aluminum one-piece that weighs 11 pounds. The entire rear sub-frame was replaced around the time I bought the car and swapped with a VLSD one.
    Brakes:
    Brake lines are all swapped to SS braided lines, as well as the clutch line. The front discs are EBC slotted rotors, and the rears are stock replacement rotors. The car has Hawk HP+ pads all around. Clutch slave and master are both about a year old.
    Interior:
    The Car has a single ebay Fiberglass bucket seat and a stock S13 passenger seat. D/S has an RCI 5/6-point harness and passenger side just a lap belt. The steering wheel is a Sparco wheel with a quick-release and hub on it. Gauges are tach/fuel level/voltmeter/oil pressure/water temp. There's room in the gauge cluster slot for two larger gauges(speedo and tach) current tach is mounted on top of the dash.
    Suspension:
    I put in solid aluminum sub-frame bushings, swapped out the lower ball joints, put in poly bushings on the LCA's and sway bars, and the remaining arms were replaced with heim joint end adjustable ones. The car also has adjustable tensions rods and tein outer tie-rods with peak performance inners. The car has Buddy Club D-Spec coilovers on it which are brand new. Rear sway-bar was swapped for the larger oem one off the rear subframe I bought.
    Wheels are Borbets 15x7 +35 set of 4, 6 diamond racing 15x8 +0 4x114.3 wheels, 4 are still brand new in box and 2 are on the car. The fronts look to fit fine without any fender rolling, and haven't tried them on the rears yet. The studs are ARP extended studs that are I think 2.5" long.
    I've done absolutely everything on this car, so if you have any questions I can definitely answer any of them and feel free to ask. As the car sits I'd like $6000 with all the wheels, $5400 with just the borbets or $5700 with just the diamond racing wheels. I know it seems like a lot, but it's pretty much a competition ready car minus power. With the megasquirt if you popped in a built ka you could boost and be done. Any questions E-mail or phone are the quickest contacts: [email protected], six sevun ate-nein three six-sevun too too ate.
    If you want more pictures I can take detailed pictures any time of anything you want.
    PHOTOS!:
    Vin is: JN1HS34P1KW008794
    price is OBO
    Gainesville, GA
    bumps!
    Senior Citizen Dylan's Avatar
    Milledgeville
    dude.u gotta be fuckin shitting me.ur playing right?
    twenty-two
    Gainesville, GA
    haha you caught me! great joke huh?
    no I'm not kidding you, you little shit. If you'd ever built anything halfway you'd know the kind of labor that goes into something like this and why it's worth what it is.
    bump.
    Gainesville, GA
    bump!
    nismo_92
    atlanta
    bump for a project car
    You dont get shit for labor. SOHC motor and a roll cage w/ shitting half ass wiring doesnt = $6k
    Im leaking VTAKK!! Burnz1one's Avatar
    Pauldin County
    if you dont like the price, please refrain from posting!
    Gainesville, GA
    Yep, thanks burnz1one. half-ass wiring? those pictures of the dash are before the wiring was done. Also wires for the radio and a couple other amenities I don't currently have for it are left dangling, hence any dangling wires. I don't expect shit for labor, that's why the car is priced where it is. I have all the receipts from the entire project and everything on the car is still brand new, and it's well over what I am asking. If you can reproduce this same car for less then do it and go make your sweet mommy proud. The wiring is all done properly, soldered with two layers of heat-shrink. All wires are wrapped and shrouded, both the engine harness and chassis harness wires are labeled every ~6 inches, so any wiring issues will be easy to sort. If anyone actually has any real concerns feel free to call otherwise get the fuck out, I don't care to deal with whiny teenagers trying to boost their post count.
    -Thanks,
    Zach
    u said it comes with a built sr20det?
    Gainesville, GA
    you guys are hilarious, anyone mind deleting all these useless posts?
    WillAgreeForReps!!
    The Town of Lula
    welcome to import atlanta lol
    Gainesville, GA
    Thanks for another useful post roscoe.
    EPIC FAIL!
    Gainesville, GA
    <3 thanks for all the help fellas! bump!
    Having built race cars, sorry, that's worth 2k tops.
    Gainesville, GA
    Haha thanks! Anyways, car now runs and drives and has a walbro 255 lph pump. Still needs a proper tune it's only running on a base tune.
    Gainesville, GA
    DurtyDubs pebojelly's Avatar
    Villa Rica
    Quote Originally Posted by zachscar
    I don't get it?
    Gainesville, GA
    The car only ran at an idle before, as the fuel pump was shot. It now has a walbro 255 lph fuel pump and it runs and drives well. I'm going to pick up a wideband and tune it properly so that it makes power and isn't running really rich. Get it?
    Gainesville, GA
    Gainesville, GA
    Got the wide-band today and planning on working on a good street tune tomorrow. All body panels are now re-installed also, going to re-do the front half of the cage and the harness bar starting wednesdayish. Wide-band will not come with the car.
    Moultrie/tifton
    Dude im sorry...run into a knife. I HAD A COMPLETED CAR with more than you could dream of i sold for 8k AND i did the work myself so i know what it takes. Fail
    Columbus GA
    Not to beat a dead horse... but you're never gonna get 6k for that car. 6k towards a rolling chassis puts you on a serious project car. Something like this cost less than 6k rolling. Is that KA worth $5k? im missing something when i add this up.
    Talontsi24 jgaff2424's Avatar
    kennesaw
    wow
    aka Paco flyNhawaiian's Avatar
    Columbia
    so the price went up now?
    2002 GS300 Sport Design
    92 Supra Turbo
    97 SC3 RSP/Black NA-T
    95 SC3 5spd black intr, VOLK, GREDDY, HKS (sold)
    95 SC3 Twin Turbo (sold)
    2k cash today, take it or be stuck with a never ending FS thread.
    Columbus GA
    i smart person would take this $2k.
    Gainesville, GA
    I'm alright thanks, If it comes down to it I'll part it out and make more than 6k. As a result of my leaving the country soon I will let it go for $5500 with the Borbets and 6 Diamond Racing wheels 15 x 8 +0(4 of which are still in unopened boxes, 2 of which are on the car).
    First off, I've been fairly cordial for all the bullshit heckling of my thread. I don't care if you don't think the cars worth what I'm asking get the fuck out and go on with your day. You lot of retards are the ones that sell these fucking pile of shit stock 240s for $1500-2000 with all sorts of problems; most of which are inflicted by idiot owners trying to do some "free modification" and having no fucking clue what they're doing. This car may not have a super-sweet SR20 like all the other fan-boy faggots out there. It is complete, it runs and drives with zero issues, and everything that's still on the car works! If any of you idiots can even come close to saying that about whatever fucking project it is you're working on then feel free to comment to your friends about how ridiculous this car and thread are, but keep it to yourself I don't need 8 pages of BS posts about why you think my car isn't worth anything. If you were looking to actually build something worthwhile for racing you would understand that this car is basically done besides power, albeit a costly part of the build it's only a minor part usually. So I love that you guys are feeling super e-thug or whatever it is you do but move the fuck on, I really don't care what you think about the car unless you want to buy it.
    Sorry for the rant, but seriously go kill yourselves for being completely useless human beings.
    Oh and the car has something of a street-tune meaning that it's drivable with, from the seat of the pants feel, about stock power but very peppy from the lightweight D/S and the light flywheel. I'm still working on the tune, and as soon as the tune is done I'll finish the cage up with new front-bars that go through the dash and a harness bar that allows more room.
    Columbus GA
    WTS Clean 240sx, has nearly perfect interior glass and trim, runs and drives and all gauges work.
    Car comes with a rollcage assembly still in the box, coilovers still in the box, a 5 gallon bucket full of wires and fittings so that you can go ape shit mcguiver on the wireing harness if you like. Car also includes a crowbar incase you want to rip the interior and bumpers off it. Buy the car this weekend and ill include a free pinetree to park it under so that its covered in sap and grime.
    $6000!!!!!!! WHAT A STEAL!!!!!
    Gainesville, GA
    Yep nail on the head right there, how could I have forgotten the proverbial bucket o' wires and the pine-tree. That does remind me though that I do need to put some up to date pictures up.
    I hope that's not directed to me, I build race cars, I even built a S13 race car before with KA, SOHC KA's are widely used in road racing, BUT 2k for this project is well worth the price, I can buy a race winning SORTED S13 for what you are asking, this is a project with an unknown record.
    Is this cage even legal? What tubing is it?
    Gainesville, GA
    It's more or less towards sinfix weird vendetta against me selling this car and having a non-garbled for sale thread. The cage is legal and it's 1.75 x .120 DOM tubing. It's a pre-bent from S&W, but I am actually re-doing the front down tubes to make them go through the dash(I do some cage work to make money). If you think the cars not worth it there's no need to share your opinion either, that's not what I am asking for, I am asking for someone to buy it and take it out and have fun with it.
    Here's some pictures after a wash today, I'll put up new interior pictures when the new down bars on the cage are in. I may also add door bars on and a new diagonal/harness bar if I have enough tubing. Should be done with the cage stuff by the end of this weekend. Also finishing the body-work and lowering the front of the car down to suit this weekend so the car will just need to be prepped and painted.
    Where do you build race-cars at Simon, mind pointing me towards some photos?
    Beater Monkey
    Lizzela,GA.,US
    i sold a 91 rhd coupe sr 20 turboed that kills this car by far for 5000 good luck
    Gainesville, GA
    who cares about rhd except fan boys same with sr20's old news kiddo. Also your sr car probably had nothing for suspension and no safety equipment, completely different car and an irrelevant comparison. Thank you have a good day. bump
    Beater Monkey
    Lizzela,GA.,US
    Ok my car sold within 3 days of posting it hw long is urs been posted? or should i say hw long is it goin to be before u take urs off realizing that u cant polish a turd to much b4 it turns white an dries up. An my car had a FULL roll cage and 32 way Megan racin suspention,skunk2 sway an lower control arms. So u might want to try auto trader. atleast then people cant reply to hand me downs there. So u have a nice nite shit dumplin
    Stockbridge foo
    This thread is some kind of joke right?Reps to the OP for being a complete idiot...
    Jason..
    Southside
    this is a nice read, glws!
    1989 240sx Coupe LS1
    2005 Srt-4
