Results 1 to 40 of 88
Thread: Skunk2TurboneticsHKSApex'iMOMOspacro
    GE8 RS
    Default Skunk2TurboneticsHKSApex'iMOMOspacro
    selling it all. everything works and all parts are new. only installed. the whole set up has at most 12 miles on it. never had it tuned or got to run it. project is unfinished. my loss is ur gain. hate to do this but its time.
    PLEASE READ: all prices are firm. i will NOT nego. no trades of any kind. please do not bother to want to see the car if u do not plan on buying anything. i will not go down on any prices. i really dont care how much u saw it on what ever website. if u find a better price else where, jump on it. i will not ship unless it is something small and u take care of shipping. i will only meet up if u pay for my gas.
    94 EJ2 DX shell gutted & stripped $500
    Engine
    JDM B16A head $800 built. 3 angle valve job, S2 pro series springs, S2 ti retainers S2 valves
    Skunk2 pro series stage 2 cams $500
    Skunk2 Pro series cam gears $150
    Hondata intake gasket $20
    B16A block with darton sleeves $1,800 with eagle rods & wisco 82mm pistons comes with new water pump, oil pump, timing belt
    ARP head studs $100
    Morosso oil pan PENDING
    Unorthodox underdrive pulleys $150 comes with ac and ps pulleys and ill include gates belts for both
    Turbonetics T3/T4 turbo $600
    Spearco intercooler $150
    B series torque mounts with bushings ac and trans. $60 each
    Drivetain
    Exedy 8lbs flywheel $100
    B series shift linkage $100
    Fuel
    Walboro 255 fuel pump $100
    Tuning
    Hondata S200 with boost option $250
    P28 ECU chipped $150
    Turbonetics 2bar map sensor $40
    Apex'i AVCR boost controller $200 comes with stand
    Apex'i turbo timer $80
    Accessories
    Skunk2 billet wire cover $80
    Skunk2 cam seal $15
    Skunk2 lug nuts $50
    NRG hood dampers $60
    JDM Type R valve cover $100
    Ignition
    MSD 6AL with MSD 2 Step $200
    MSD 8mm wires $50
    MSD pro cap $20
    obd1 vtec dizzy with msd cap $120
    ok ignition package deal!!! $300 for 6AL, 2step, dizzy, cap & wires, and blaster coil!
    Suspension
    Skunk2 lower arm bar $80
    Exhaust
    Custom down pipe $80
    Exterior
    JDM Nukabe tow hooks $100 both front and rear tow hooks
    password JDM foglight kit $100
    Urethane Type R rear lip $40 damaged
    EK4 side skirts $60
    VIS invader carbon fiber hood $150 clear coat has spider cracks. needs new clear coat
    JDM EG6 fenders with sidemarkers $120
    JDM EG6 sidemarkers alone $30
    Interior
    Sparco Fighter seats $300 EACH comes with sparco slider and backet
    Sparco 3 point harness $60 each
    Sparco gun metal harness bar $200
    Sparco steering wheel hub adapter $40
    Carbon Fiber door panel inserts $150
    MOMO weld-on quik release $200
    misc. items
    NIB Greddy t-belt for B16 $80
    B16 oil pan tapped for boost $60
    B16A2 block stripped needs to be honed $50
    oem crank pulley $40
    oem antanna block off $20
    PIAA H4 bulbs $20
    pm or email me at [email protected]
    Attached Thumbnails Attached Thumbnails -cimg0598-jpg   -cimg0599-jpg   -cimg0601-jpg   -cimg0607-jpg
