Thread: Spray bed-liner Engine Bay?
    Default Spray bed-liner Engine Bay?
    It's common to do the outside of rock-crawlers and 4x4's that see constant abuse but what about engine bays? Will petroleum products break it down? There's oil inside rubber engine mounts aka hydraulic mounts sooo that doesn't make sense.
    You can add pigment/paint making it any color you want. The hard durable surface can be degreased, scrubbed, pressure washed, etc. without fear of damaging the surface.
    Other than weight, what would be the downside of coating the entire engine bay with a spray in bed-liner? Heat resistance? I would be using gold foil every where heat may be an issue anyways; ie. the fire wall and shock tower on the exhaust manifold side.
    Explain, good or bad...
    423 KING
    Chattanooga, TN
    i had the whole outside of my jeep done, other than fading and it running hot it was pretty cool lol
    All the resources I have found say Speedliner is the way to go over Line-X or Rhino Lining.
    S P E E D L I N E R
    http://www.speedliner.com/
    I'm thinking use Por-15 then do the Speedliner on top of that, both the under carriage and the engine bay. I'd be curious to see what the weight per square foot would be.
    423 KING
    Chattanooga, TN
    S P E E D L I N E R
    this seems like alot better for bays since it wont have to bake on like rhino lining
    423 KING
    Chattanooga, TN
    my rhino liner was pretty heavy also, im sure linex or something like that wouldnt be too bad
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    thought about it before, seems like a reasonable idea to me. I see no downside since it is a lot cheaper than all the shaving/tucking and custom paint that is so popular.
    Who knows?
