Results 1 to 13 of 13
Thread: single cam cable trans
    Stang Mod slostang's Avatar
    Southside
    Default single cam cable trans
    im literally having to force it into gear nearly every time i shift. i changed the fliud with syncromesh today and it didnt help any... help?
    JohnBobAlingAdang 88NaCivic's Avatar
    Walton Cnty
    Sounds like either pressure plate or throw out bearing- does it make any noise?
    Southside
    none at all. and from what i understand its a fairly new competition stage 2 setup.
    Walton Cnty
    LOL yep the same setup I had stage 2 clutch a pressure plate.
    I couldn't even install the PP, well I did but it never worked correctly. clutch was fine PP gave me the problem.
    mine was so bad you couln't even get it into gear.
    I would say the pressure plate.
    Did you have any other problems with the tranny before?
    Southside
    nope. i was at the track and then it just decided it didnt want to go into gear... every once in a while it goes into gear fine. most of my problems are in 1st and 2nd. 3,4,5 are tolerable.
    Walton Cnty
    hmm interesting... Which tranny are you running and how long has that CC been on it? Mileage on the tranny?
    either u need to adjust your cable more. or u need a new clutch kit.
    Southside
    fuck.
    North Augusta, SC
    Slovic, check your phone.
    Back to being stock and slow
    Southside
    replied...
    Middle, Ga
    Damn, man. Hope you get it worked out and it isn't too much. My damn brakes just decided to almost die on me. So, I got to get that shit fixed.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    Definitely sound like a clutch issue. I would check the cable first though, with an upgraded pressure plate it is possible to stretch the cable, causing a lack of complete disengagement.
    Who knows?
    Southside
    yep it was the cable. it was out of adjustment and very weak. it held for about 300ft. down the road after it was properly adjusted lol. i got a oem one on the way though!
    Thanks guys and +11
