Thread: crx dpfi-mpfi swap
    im down right fierce hadouken's Avatar
    Default crx dpfi-mpfi swap
    i swapped my crx from the d15b2 to the d15b7 and me and a friend wired up everything and all im getting is a click its not turning over any help? we looked up all our information on honda-tech.. the starter is still good, fuel pump cuts on, do i need to buy the obd0-obd1 conversion or can i splice wires into the obd0 ecu... b/c thats the way we have it now. we have the obd0 wireing harness 0bd1 dizzy... any help will be appreciated
    SOUTHSIDE
    check the ground on the wire harness...right on the thermostat housing
    earth ????
    its connected ! next...
    Titties!!!
    some wires may have to be switched for the dizzy, iacv has to be switched and a few others. where are you located b/c it could be a number of things causing chaos. i have looked into converting my hatch for about 2 years. make sure the ecu you are using supports the sensors in the dizzy. i think the TDC, CKP, and another sensor is in the dizzy and if not wired right our not going anywhere.
    im near downtown winder but the car is in winder too but its on the other side of town at my friends house
