Results 1 to 40 of 53
Thread: My work in progress
    Default My work in progress
    First off, I'd like to say that I almost got aay with scamming you all. My actual screen name is:
    JITB!
    ENGINE:
    95 JDM H22a,
    R&D Dyno P&P head w/ welded chambers,
    Supertech valves,
    Supertech dual valve springs,
    Supertech titanium retainers,
    Crower custom cams (R&D Dyno custom specs),
    BDL cam gears,
    ARP head studs,
    Cometic HP 89mm .030 head gasket,
    Sleeved and built by JG Engine Dynamics,
    Resurfaced deck,
    H23 polished crank,
    Crower Econo billet rods,
    Custom 89mm CP pistons and rings,
    Ultra balanced,
    Removed balance shafts,
    ACL race rod & main bearings,
    Fluidampr race spec harmonic balancer,
    DH-Racing custom intake manifold,
    RPM 79/76mm throttle body,
    Custom 3 1/4” cold air intake w/ heat wrap,
    Coolingmist N/A dual nozzle water/alcohol injection kit,
    Denso iridium plugs,
    Nology Hot Wires,
    Linage ground wire kit,
    Crane ignition system w/ coil,
    Mugen chipped p28 ecu,
    Apex-i VAFC, AEM fuel filter,
    B&M fuel pressure regulator,
    Hasport motor mount kit,
    PWR radiator,
    Derali slimline fan,
    OBX coolant tank,
    AN-R tubular 4-1 header w/ 2.5" collector w/ header wrap,
    Apex-i N1 turbo muffler
    Driveshaft Shop custom Stage 2 axles w/ Pro Drive H22a hub kit (Chromoly H22 outer CV’s),
    ACT 6 puck clutch plate,
    ACT Extreme pressure plate,
    Fidanza light weight flywheel,
    Accord shifter assembly (shortened 1"),
    DC Sports short shift adapter,
    Skunk 2 440g weighted shift knob,
    Totem traction bar w/ custom front motor mount by Autotech Motorsports
    SUSPENSION:
    DC Sports front and rear strut tower bars,
    DC Sports rear lower tie bar,
    Tokico Hp struts,
    Skunk 2 coil-overs (94-00 Integra),
    95 Civic Si front lower control arms,
    Eibach 26/17mm anti-roll kit,
    95 Del Sol Si rear end links,
    Energy Suspension end links
    BRAKES:
    Axxis "Ultimate" brake pads (front & rear),
    94 Integra GSR rear disc brake & suspension swap,
    Brembo slotted & cross drilled rotors,
    Integra 40/40 proportioning valve,
    Wilwood 570F dot 4+ brake fluid
    WHEELS AND TIRES:
    Enkei RSF-2 15"Toyo Proxes RA-1
    Still working on it... only older pics from back home, i got they are small..
    Attached Thumbnails Attached Thumbnails -4921430017_medium-jpg   -4921430021_medium-jpg   -4921430020_medium-jpg   -4921430076_medium-jpg   -4921430079_medium-jpg
    more pics
    Attached Thumbnails Attached Thumbnails -4921430031_medium-jpg   -4921430068_medium-jpg   -4921430029_medium-jpg   -4921430027_medium-jpg   -4921430090_medium-jpg
    damn other than the kit, I see some good work done.
    ALL CAPS JITB's Avatar
    definatly NOT cool pics bro
    Dunwoody/Sandy Springs
    RRRRRRIIICER
    Warner robins ,Ga
    sick setup...what kind of power are you making?
    EE OG Revmaynard's Avatar
    Cool body kit bro.
    Bozzio for president.
    Senior Member G.C's Avatar
    Forgot
    Nice build. Ugly car
    :idb:
    Senior Member 4DrTeg's Avatar
    ..dunno why everyone always has to hate on a car that isn't jdm..its your car and you should do what you like..but with that aside, nice build man what numbers you pushing?
    Quote Originally Posted by xdavidscenex
    235, last dyno before the head work
    EAT DOG white_rice's Avatar
    lawrenceville
    good sleeper
    your moms house
    nice swappp but not liking the body kit but is ur car gl !!!!
    (((((No more 4 door))))))
    Quote Originally Posted by 4DrTeg
    I dont think it has anything to do with being JDM or not JDM, some shit is just tacky, regardless.
    Da Nastyist Whipz Member #9
    1% ER. twiztid cc's Avatar
    over yonder...............................................................yeah here
    love it man looks good
    Quote Originally Posted by bdydrpdmazda View Post
    I love porn, the gay kind
    Quote Originally Posted by 03RCode View Post
    Quote Originally Posted by b@d @pple View Post
    i would slit her throat then fuck the hole
    Quote Originally Posted by Terror
    timestwo
    NW Boonies
    brought me back to 00'
    ~DB4LYFE
    07 Honda GD3
    lol since when did stock cars become so fun!
    WillAgreeForReps!!
    The Town of Lula
    so true!!
    No
    lulz
    So, according to your "logic," everyone has to like everyone elses car? Everyone has to just cast aside their personal tastes just so they won't be labeled a "hater?" You don't think your comment was just a tad ridiculous? Later, QD.
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    yO! Your Whip is tHe illest! I would paint the mirrors and windshield wipers yellow if I wEre yoU!
    gOoD Work! Keep it up!
    Quote Originally Posted by joseph dale
    Since they had less vents than your house.
    ASAP AssHole WTF?'s Avatar
    Woodstock/Kennesaw
    dyno sheet?
    Woodstock/Kennesaw
    X2 this guys speaks the truth
    ┌∩┐(◣_◢) ┌∩┐ 809KiNg's Avatar
    Quote Originally Posted by _Christian_
    el oh el
    Quote Originally Posted by Frög
    are you serious
    Woodstock/Kennesaw
    ^ no hes not serious
    West Staines
    why stop there? i'd paint the whole windshield.
    Go Skateboard. ItsBlack's Avatar
    how long have you had the car? that's a lot of work done
    Quote Originally Posted by 809KiNg
    are you serious
    Dumbass. Later, QD.
    straight ninja mode EuroTra$h's Avatar
    canton
    Dumbass. Later, QD.
    QFT ha ha
    are you serious
    Miss my Civic.
    Dang, you should have actually pm'd me about the race. For sure would have been worth it.
    Sucks.
    yeah i guess your right
    Blistered Blazer
    Norfolk, VA
    sweet set up
    NIKON
    Squad member | Nikon D70s
    ..unknown
    Good build.. definitely a sleeper because I wouldn't expect this car to have a H22
    somewhere, GA
    nice set up.....not feelin the body work tho. Props for a fellow H swap!
    '82 TE72 SR5 Sport Coupe
    3tc
    SwiperNoSwiping!!
    The body kit shocked my eyes lol, good build though!
    u remind me of a wigger !
    Woodstock/Kennesaw
    Quote Originally Posted by WTF?
    Shite!
    I don't get it. If you're going to claim another's car as your own, couldn't you at least choose a good looking car? Later, QD.
