Results 1 to 2 of 2
Thread: s14 kouki wing, injectors, bov
    Green and Gold
    Carrollton, GA
    Default s14 kouki wing, injectors, bov
    Ok, I've got a few items I need to clear out.
    first on the list, my kouki wing, it's a fiberglass knock off, but in good shape, it was cracked when I bought it but I fixed the cracks using 3 stage marine epoxy, it'll last longer than the fiberglass. needs paint and it's ready to go.
    $150 takes it.
    (I'd rather not ship this, but I will at buyers expense.)
    second, a set of 4 Nismo/Tomei 555cc injectors, these are the yellow top/new style injectors. they are all brand new never used. will ship these for $10 anywhere in US. pickup preferred.
    (we had a set of these injectors flow tested at RC and they actually flow 615cc)
    $350
    third, unknown model ARC blow off valve. It's used and in great shape. comes with pipe and flanges. (already welded to a alum. tube)
    $120?
    fourth, my oil cooler setup. earls lines and fittings -8. unknown brand sandwich plate, mocal 25row oil cooler. part # OC5257-10
    description: 25 row 235mm -10 JIC
    just need a thermostat and your ready to start cooling some oil.
    the cooler is a little warped, one of the fittings broke off, but I had them both professionally re welded (I can't weld alum.) could re-paint if desired. it still works fine.
    $300
    fifth, stock SR injectors 370cc. green, new style connector, pulled from a running motor, Ohm tested ok.
    $100
    All items in Charlotte, NC. but i get back to atl pretty often.
    interested?, let me know, want more pics?, let me know pudhammeratyahoodotcom
    trades: s14 rear camber arms, s14 stuff
    Attached Thumbnails Attached Thumbnails -mocalside-jpg   -mocalsticker-jpg   -dsc_0269-jpg   -wingend1-jpg   -wing-jpg
    Green and Gold
    Carrollton, GA
    need to get this stuff gone.... trying to buy rb!
