Thread: oil feed line help.
    Senior Member cm7k24's Avatar
    kennesaw
    Default oil feed line help.
    i got my turbo kit all on except one thing,
    i can't figure out how to tap oil from the pan,
    any one around the kennesaw area that can help out??
    oh yeah its a 91 DA
    is this is LS or GSr .. thought i letcha know i have a already tapped GSR oil pan, iono if it will work for yours but if GSR then .. i got one locally for you also from cobb county..
    /Oo ___A___ oO\
    |=_/_______\_=|
    kennesaw
    its an LS.
    hmm iono if you cna use it or not but .. lets see if some1 else can chime in.. 8D but if anything i have mines FS if it fits your application 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    kennesaw
    hmm.
    well let me know if it will work.
    Augusta Ga
    it will work .
    93 sol Si
    95 sol S
    95 sol Si
    kennesaw
    100% it will work??
    Augusta Ga
    all b's are the same oil pan except for the b20a5 . i have a b18b1 oil pan on my b17a1 GSR . and dont you mean return oil to the oil pan and not "tap it from the oil pan" ????
    93 sol Si
    95 sol S
    95 sol Si
    Jun 2009
    oh yea it will %100 work.
    vanilla sky.
    the b18c (gsr) oil pan is different from the ls/
    You need to get your oil "Feed" from the back of the block, or the side of the head... Preferably where the oil psi switch is located. The oil return needs to go into the pan, as straight as possible, no kinks or funny angles.
    vanilla sky.
    ^also needs to be above oil level/
