Results 1 to 10 of 10
Thread: obd2 gsr into obd1 del sol
    Certified Gearhead kbiais's Avatar
    conyers
    Default obd2 gsr into obd1 del sol
    to clarify myself could i use the obd2 ecu and wiring harness from the gsr for my swap into my sol does ne one know how to make this work preciate it
    u can with a lil work but would would u want to.
    Augusta Ga
    why would you ??
    93 sol Si
    95 sol S
    95 sol Si
    Get a OBD2 to OBD1 jumper or run a chipped ECU. Not sure which one though. Not up on my ECU codes these days.
    Augusta Ga
    sell the ecu and buy a OBD-1 ECU and change the sensors off your d series motor and BOOM ... your swap is obd1 and youll have a GSR SOL .... end thread/
    93 sol Si
    95 sol S
    95 sol Si
    Quote Originally Posted by redciv1
    slow down there buddy that plan will not work at all.
    Quote Originally Posted by 1SOL2NV
    that will and is the best route.
    Augusta Ga
    lol i was going to say something but i chose not to .reps ^
    93 sol Si
    95 sol S
    95 sol Si
    NOOOOOOOOOOOOOOOOOOOOOOOOoo
    Use the FACTORY harnesses that came with YOUR car. Modify them to work with your New engine... and chip your p28/p06 to run your gsr, or find a 94-95 gsr ecu...
    LAWRENCEVILLE
    the obd2 integra harness will plug right into the delsol and work fine! he will need a obd1 ecu! but the harness will work!
    Hella stock member!
    conyers
    preciate it fellers
