Thread: Used - Alphasonik PMA800DA Class D Mono-Block Amplifier - $175
    Purevil lowjack's Avatar
    Suwanee, GA
    Default Used - Alphasonik PMA800DA Class D Mono-Block Amplifier - $175
    SOLD !!!!!!
    This unit is slightly used, and comes in the original box. It was removed from the Purevil 350z showcar after the final DUB show in Atlanta, in 2007. It won best Sport compact Audio System that show. This Amp was the main stay for my subwoofers and performed flawlessly.
    This will make a excellent addition to any build out there. Good straight power that matches perfect with a set of 10's or a 12.
    http://www.steelenvisions.com/pe-online/index.htm (Link to my last car build, Purevil 350z)
    As a former sponsored car builder for Alphasonik I have what is left of my equipment to sell off. Dont miss your chance to get great gear at a fraction of the prices online.
    Please see my other adds for other Amps, EQ's. Sub woofers (including a 15 inch Mayhem), Componet speakers, and Professional Line Filters.
    1-Channel Class D Monoblock Power Amplifier
    RMS Power Rating: 1640 watts x 1 chan. at 1 Ohm Mono
    RMS Power Rating: 1200 watts x 1 chan. at 2 Ohms Mono
    RMS Power Rating: 800 watts x 1 chan. at 4 Ohms Mono
    Hour meter
    Remote mount digital voltmeter
    Remote bass boost control
    Heavy duty heat sink
    Beveled clear acrylic protective cover
    Tiffany-style input and ouput RCA jacks
    Removable covers for control and input areas
    High speed switching power supply
    Double-sided glass epoxy circuit board
    THD: 0.08%
    S/N Ratio: >100dB
    Frequency Response: 15Hz-150Hz
    Variable Low Pass Filter: 50Hz-150Hz, 24dB/oct
    Variable Subsonic Filter: Off-20Hz, 24dB/oct
    Variable Bass Boost at 45Hz: 0~+18dB
    Variable Phase Shift: 0-180 degrees
    Input Impedance: 10K ohms
    4-Way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
    On board hook-up terminals
    Dimensions: 15 3/4L x 9 1/8W x 2 1/2H
    Scott
    2009 F-150 SC
    2011 Chevy Camero LT2
    2007 Yamaha R1
    2009 Harley Davidson Softail Night Train (Sold)
    1991 Bayliner Ciera 2655 SunBridge (Sold)
    2008 R32 (Sold)
    2001 Golf "Orig BTERCAR" (Sold)
    2004 350z "Purevil" (Retired/Sold)
    TeamECI forever!
