Results 1 to 1 of 1
Thread: Alphasonik PEQ20LX 20-Band EQ, Crossover, 8-Volt Line Driver - $200
    Purevil lowjack's Avatar
    Suwanee, GA
    Default Alphasonik PEQ20LX 20-Band EQ, Crossover, 8-Volt Line Driver - $200
    Alphasonik PEQ20LX 20-Band EQ, Crossover, 8-Volt Line Driver for sale!
    SOLD!!
    These sell for over $399.00 on the net and the MSRP is $599.00. This is a STEAL for a competition level EQ/Crossover!
    This unit is slightly used, and comes in the original box. It was removed from the Purevil 350z showcar after the final DUB show in Atlanta, in 2007. It won best Sport compact Audio System that show. This EQ is in great shape and was the center piece of my build. Of all the audio gear in the Z, this was by far the most impressive. You are able to contol everything from the front to the rear of the auto with percision. You will not be disappointed with this unit and it will pump up anything you have +8 Volts. If you are looking for competition grade hardware and performance you have come to the right place.
    http://www.steelenvisions.com/pe-online/index.htm (Link to my last car build, Purevil 350z)
    As a former sponsored car builder for Alphasonik I have what is left of my equipment to sell off. Dont miss your chance to get great gear at a fraction of the prices online.
    Please see my other adds for other Amps, EQ's. Sub woofers (including a 15 inch Mayhem), Componet speakers, and Professional Line Filters.
    PEQ20LX:
    20-Band Graphic Equalizer: +/-12 dB
    2-Way Fading or 3-Way Non-Fading Crossover @ 18dB Per Octave
    Variable Low Pass Sub Channel Crossover: 40Hz - 400Hz
    Variable Band Pass (or Rear High Pass) Crossover: High 40Hz - 800Hz & Low 2kHz - 7kHz
    Variable High Pass Tweeter or Front Crossover: 40Hz – 8kHz (w x10 switch)
    Subwoofer Phase Control: 0~180°
    Variable Bass Level: +18dB
    Variable Q: 2-20
    Variable Front/Rear Fader for 2-Channel Input Systems
    Variable Input Levels for All Channels
    Equalizer Bypass Switch
    Stereo/Mono Subwoofer Switch
    Band Pass/High Pass Midrange Switch
    Parallel Input Switch for Fading or Non-Fading Operation
    Remote Bass Control Module and Adjusting Bass Level and Filter Q
    18dB per Octave Crossover Slopes
    RCA Outputs: Sub, Band Pass (or Rear High Pass), Tweeter (or Front) High Pass
    Attached Thumbnails Attached Thumbnails -img_9954-jpg   -img_0739-jpg   -img_1372-1-jpg
    Scott
    2009 F-150 SC
    2011 Chevy Camero LT2
    2007 Yamaha R1
    2009 Harley Davidson Softail Night Train (Sold)
    1991 Bayliner Ciera 2655 SunBridge (Sold)
    2008 R32 (Sold)
    2001 Golf "Orig BTERCAR" (Sold)
    2004 350z "Purevil" (Retired/Sold)
    TeamECI forever!
