I'm gonna be guttin my bay soon. And droppin in the poor z6 in..give me some advice in what I should do and NOT DO!!! Lol thanks team
clean and paint the bay wile the motors out..
Can't no money to spend like that...but I am gonna clean the bay as good as possible lol
wire tuck
Soon!!
Get duplicaolor spray paint from autozone, advance, o' reilys, etc... Just get the color code to your vehicle. Get Clear as well. Then get some filler primer.
Sand down the bay.-320
spray the filler primer.
wetsand slightly-400
let dry
lay down your color. However many coats you want
spray clear.
^^^ that foooool speaks the trooff
Thanks purp
No prob, man. And it's relatively inexspensive. you're looking at maybe 50-60 for everything. Cans will run you 5 bucks -/+, you'll need about 4 - 5 cans of color. Then about 2-3 cans of clear. Sand paper is relatively cheap. Primer will be about the same as other cans.Originally Posted by p3tey2
When you're done, it will look so so so good and you'll be a lot happier with popping your hood.
lol..i bet..but i just want my motor to start for rite now lol..thanks again
wire tuck makes any swap clean.. trust me
the easiest wire tuck you can do is to run the wires of the harness thru the inner fender wall. its simple, clean, not fully through, but effective.. and you would be able to that without dropping the motor out unless its already out
sounds good thanks...ATTN PURP do u know how in the word to make custom headliner and door inserts fro a mannual door?
