Thread: need help map sensor problem
    Yum-Yum Racing
    Default need help map sensor problem
    i have a 00 integra with a jdm b20 in it im running and obd 1 ls ecu
    i check my cel for codes.
    i came out with number 3
    MAP sensor
    so i changed the map sensor disconnected the battery and reconeccted light still comes on for samde thing?
    test the sensors if they work fine check your wiring.
    Yum-Yum Racing
    I label my sensors the map sensor checked out fine I think its conv harness or ecu
    Quote Originally Posted by DaybreakSaint
    how did u test the map
    Duluth, GA
    I have a spare map if you end up needing it mike
    had anything changed/work done recently just before the code started? a lot of times when people do a swap, change tb, or intake the map and tps get mixed up since they have the same plug. the map you changed, was it new or used...are you sure the one you change was good? if so, there could be an issue with the wiring.
