Results 1 to 4 of 4
Thread: Stripped Nut
    At Home
    Default Stripped Nut
    Options in taking it off. Shit is horribly stripped.
    I need productive answers, comments, and methods.
    Methods Ive used.
    WD-40
    Vice Grip
    Slow&InControl! LokiSays's Avatar
    I would say grind off the head of the bolt to make it square and use a adjustable wrench to try and remove it. Worked for me before. Hope that helps. Use the WD-40 to lubricate it.
    SwiperNoSwiping!!
    Quote Originally Posted by LokiSays
    Yes, this can work... and if you're good with a grinder/cutting wheel you could also easily cut the nut and just separate it from the stud/bolt.
    GL with it!
    u remind me of a wigger !
    MCD
    there a special tool you can get at auto zone for that......it would take 3 sec after you put it on
