Results 1 to 13 of 13
Thread: No power to fuel pump (what to diagnose?)
    . eg mike's Avatar
    ga
    Default No power to fuel pump (what to diagnose?)
    I installed a full main harness in my car Saturday and after done, no power to the fuel pump.
    I tried 3 different main relays and still no luck.
    I checked Fuse 18 and its good.
    Anyone know what I should check for next?
    do u have power going into the main relay
    . eg mike's Avatar
    ga
    Yes I got a constant hot on the white wire I believe with test light.
    so your test light works?
    Are you trying KNOWN working Main Relays???
    Is your ignition switch working ? not the lock cylinder the electrical part?
    all your plugs firmly installed correctly and was this a used or new harness? if used did you check for cut wires,burnt,cracked,wires?
    Have you tried hitting your dash with your fist lol
    Quote Originally Posted by eg mike
    there has to be a fault in the new harness someplace. if u have power going out but nothing at the other end.
    Privateer Racing!!
    Duluth,Ga
    Put the pump on a seperate relay then ,use a 12v soure and toggle to trigger the main relay on.
    Attached Thumbnails Attached Thumbnails -relaywire-jpg
    PURP-a-trader PURP's Avatar
    Damn, Mike. I'm having the same problem... shit's gay
    Hwy 315
    Check your thermostat ground - according to the schematic, that's where the relay gets its ground.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    Quote Originally Posted by se7en
    -jonathan
    bingo. 90% of the time after swapping a harness, people miss a small ground somewhere.
    Who knows?
    Titties!!!
    Quote Originally Posted by hondabuilder
    these are there for a reason' i hate electrical troubleshooting but the first thing i check is it grounded.
    North Augusta, SC
    he figured out the problem... Was the relay... The three he tested were all bad.
    Back to being stock and slow
    Hwy 315
    Quote Originally Posted by Motivation
    Lol - sad... Almost typical of a Honda relay.
    -Jonathan
    [/URL]
    . eg mike's Avatar
    ga
    Yeah, I tested them on Sunday when it was like 85 degrees outside..... I re-tested last night after going through the schematic and was about to give up and tried the main relays again. Got 1 to work!
    I should of known the heat would of got to the relays! The solder on them crack from heat and its screws the connection up!
    Well coupe is running smooth, and I am excited to finish putting it back together!
    Thanks for all the comments guys!
    Purp try some other main relays :P
