Results 1 to 10 of 10
Thread: Accidently Over filled oil on my boosted B16.
    K24/K20 love
    Default Accidently Over filled oil on my boosted B16.
    Well today I accidently over filled my oil. I thought it was at a leveled position so I check the oil and it seemed low. I added 1 1/2 quarts, and it was a little over the second dot on the dipstick. I drove around and it started blowing white smoke out not even in boost. I wonder if this has anything to do with the extra oil that I added..
    I guess its time for a compression test... Or may be the turbo seals going bad.
    IA's Pedo-cord tdurr's Avatar
    Fayco
    or time to drain out the extra oil then go from there. how far did u drive with the extra oil in the car?
    Save ur engines!
    Teh Womanizer NVEOUS's Avatar
    Oct 2008
    Carrollton
    White smoke. hmmmmm what does it smell like??
    AWD Member LostSolVTEC's Avatar
    NOT in Georgia
    white smoke is usually coolant, but when an excessive amount of oil gets in the exhaust it can come out white too.
    Like the second poster said drain it out and start over with the correct amount of oil. If it still does it troubleshoot from there
    if its just a hair over the second dot, its probably not the cause of your smoking. i always ran an extra half-quart on my boosted d16.
    drain the oil dont over fill problem solved
    dc5
    ATL, GA
    if its a tad over the second hole, your fine.. Your smoking could be oil going into your downpipe/exhaust through your turbo..
    1/2 Fast Motorsports highspeed's Avatar
    Gardendale AL
    sounds like you got other problems if you are putting that much oil in your motor. Im with green91 on this
    jupiter
    my car smokes quite a bit too when not in boost and from what i gathered its cause i have no oil restrictor on my turbo and its gettin too much oil psi and blowing past the seal on the exhaust housing...........as far as the oil level goes just drain some out and add till its good or better yet just do an oil change and put the right amount. the correct amount for a b16 i believe is 4.2 quarts..someone correct me if im wrong!
    Quote Originally Posted by dkjohnson04
    for oil change, including filter 3.8qt
    for oil change, without filter 3.5qt
    total fresh built motor 4.5qt
    straight from the FSM
