Results 1 to 17 of 17
Thread: car wouldn't start
    EF Squad
    Default car wouldn't start
    So I decided to clean up my car today since it been sitting in the driveway for 2 weeks. Then I tried to start the car but only hear constant clicking which I believe is coming from the starter. This is from a 96 honda civic dx stock, no mods or anything with an exception of viper alarm and installed sunroof.
    Some of the methods I tried were:
    1. Jumping the battery
    2. Check for sparks from the spark plug wires
    3. Open up the distributor cap to check for dust or rust build up.
    4. Check fuses
    5. Check the inside of the throttle body and found some gas inside (don know if that is the right procedure to check if gas is going in).
    Anyhow, any suggestions or advice will help.
    Certified Gearhead schia89's Avatar
    Oct 2008
    Most likely your starter is bad. Try hitting your starter with something thats not metal like a wooden stick and it may kick on.
    auto or manual. try to spin the motor over by hand. to make sure it hasnt locked. i doubt but have to eliminate it. if all well pull the starter have it tested. replace if need be.
    Yo face! SUBY_RUE's Avatar
    in the land of ozz
    Quote Originally Posted by schia89
    ^^ use a screwdriver and hit it with the handle as someone trys to start it...
    For one hell of a life
    I got my girl got my family
    For a hell of a time
    HELLYEAH!
    EF Squad
    Wait if it's the starter I would hear onlyone click wouldn't I? This case I hear series of clicking
    Dec 2008
    Northside
    are u getting gas? does the fuel pump come on? u could take out the starter if u wanted to and get it checked to start eliminating things. if u dont want to do it i can take out the starter and we can get it checked
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Sandy Springs
    Multiple clicks sound like its not getting enough current to the starter. I know you said you tried jumping it but some jumper cables are crap. Swap the battery out of your EF and clean the terminals. I think that will work for you...
    Oct 2008
    How many volts are you gettin from the battery?
    Dec 2008
    Northside
    i got a battery from my ef or my brand new from my coupe LMK u can come get it and we can fix it
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    EF Squad
    I tried starting my car again and same result; since I been doing that it sounds like my starter is getting weak. Don't think it could be the battery since all functions work and didn't sound like losing power. Then I unbolt one of the nut to the fuel filter and saw some gas in it.
    Thxs for the battery offer Luis; think u can get me a hand sometimes LOL.
    Also I tried the method of banging on the starter while someone turned the key but didn't work (don't know how hitting it will make it start LOL)
    EF Squad
    Don't have the tool for voltage measurement
    whuttt!i got a SAAB!
    Apr 2009
    this is happening to one of my cars but after a few attempts (yes iam hearing a clicking sound ) it turns on iam thinking its my spark plugs
    gone old school C-loS109's Avatar
    somewhere
    Quote Originally Posted by Tensa_Zanget
    sometimes started get stuck internally and hitting it while it tries to start the car usually helps to get it unstuck...
    i had the same problem... it was the battery... even though everything worked inside. but mine would start when getting jumped.
    =EJ-EG SQUAD SUPPORTER=
    2000 HONDA CIVIC - SOLD
    1966 MUSTANG COUPE - TRADED
    1989 FOXBODY MUSTANG - DD
    Sandy Springs
    Just put another battery in it. Just cause you "think" its fine doesnt mean it isnt. It can not be fuel or ignition related cause the engine would need to spin over for this to be apparent. One solid click or no sound at all points to the starter or engine being locked up. Many small clicks point toward a weak battery.
    Take it as you will but I feel it may help....
    EF Squad
    Got it fixed! Swap with my bro's battery and it worked like a charm. Thxs for all the help guys; rep to all
    Sandy Springs
    . eg mike's Avatar
    ga
    Beat me to it, Battery.
