Results 1 to 11 of 11
Thread: 96 civic rear disc conversion
    Default 96 civic rear disc conversion
    alright so im getting a conversion tomorrow from an integra. Im getting the whole conversion. but i think i would have to change the master cylinder, brake booster, and proportioning valve? and i think i would have to use 99-00 si e brake cables??? im confused from other forums. help!
    btw: the car is a 96 ex coupe
    damn. any1?
    ok havent done this in awhile but if i remember currect. a non abs teg master and booster. a pp and e brake cables from a si. an any teg rear disks.
    EF Squad
    dont think u need any of that because my brother got a rear disc conversion from an integra onto his civic hatch and didnt require those.
    Quote Originally Posted by Tensa_Zanget
    did require what
    Yours is a ex you don't need to change your master cylinder or brake booster, but you will need to change your proportioning valve to a 40-40 one (dx and si are the same). You will need a 99-00 si e brake cables.
    PWN
    "but i think i would have to change the master cylinder, brake booster, and proportioning valve? "
    Nope, just get the rear disks conversion from a 94- 01 integra and bolt them on. You only change all those listed above if you wanted your brakes to be shorter or more sensitive.
    Yo mama
    Quote Originally Posted by phuoc_dat
    thats kinda the point of upgrading brakes unless he/she wants to do it for show only.
    Im a killer
    HE can do it for the rear disk. EAsier replacing and grips a little better than drum
    Loganville
    I recently did a rear disk conversion on my 97 dx civic and used the cables that came with my rear disks and it worked fine. The cables seemed a tad shorter than my stock ones, but they worked fine
    Ballin' on a Budget
    AccuracyPerformanceAutomotive
    I converted the brakes on my 88 dx turbo hatch with rear disc brakes off a 95 civic EX 4 door. Everything swaps right over and I used my factory e brake cables. You just have to adjust the cable in between the center console tighter, but everything else fits and operated just fine.
