Results 1 to 11 of 11
Thread: need a fast help for oil pan bolt
    Senior Member Schugg's Avatar
    Default need a fast help for oil pan bolt
    its stripped out, how can i get it off?? i was thinking of getting a dremil and cutting a slot in it and using something to kinda screw it off.
    haha guess this wont be happening to fast....cause i dont get this shit off so i can change my oil, im going to fucking go crazy and JB weld those locking plyors to it over night.......cause its just slipping right now and if that some how doenst work im going to change the whole oil pan, which i do not want to do, but i have another one from my old engine.
    Boosted 4door
    you should be able to get it off w/ some vise grips.
    Patience Pays...
    I have the same problem with mine right now, I'm taking it to a shop that can fix the bolt without replacing the pan.
    you wouldnt belieeeeve how tight i had my vise grips on it. it ended up just pretty much rounding the bolt off worse. if i ever do get it off without changing the oil pan im putting the bolt in it from my old oil pan. and when i said JB those locking plyors in my last post i meant vise grips. haha i just couldnt think of the name.
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    apparently this wasnt to fast! haha i still havent got it off but havent really tried much. i think im gonna bust out my JB weld idea.
    Riding for Alzheimer dazn's Avatar
    atlanta
    they make tools to remove damaged and stripped nuts and bolts
    if that doesnt work, weld a another nut on it, and use that nut. what ar you using to take it off? the vise grips? do you have wrenches or sockets?
    i was using a wrench at first, then that started stripping it out, then i tried a socket and it got worse, then i thought for sure the vise grips would get it, but they didnt. i was thinking of trying to weld another bolt on it, i seen that on another post on here to get someones lug nuts off. but ill try that.
    make sure you were loosening it lol... vise grips should do that shit... spray some penetrating oil on it let it sit..... then put the vice grips on it n tap it alil... best info i can give ya..unless you get one grip all sockets like someone said /\/\/\/\
    atlanta
    where you using the right sized box end wrench, it shouldnt do that if was the box end and the right size.
    yah i was making sure i was taking it off not making it tight. the reason it may have started getting stripped was i used the opened in part of the wrench, and i probably wasnt getting a a good angle on it. cause i used one of the lil come with the car jacks, and there wasnt much room.
