Results 1 to 21 of 21
Thread: Moving in sale (will be updated as I find more stuff)
    Senior Member iam99x's Avatar
    Athens
    Default Moving in sale (will be updated as I find more stuff)
    20% discount if picked up or met locally!
    No need for any of this. You can test any of it before buying.
    -The links I had posted up for more info were requested to be removed, and the information copied and pasted or my thread would be deleted. Whatever, done.
    3com OfficeConnect 16 port Dual Speed Switch - -
    $45
    I can't find the power adapter to this, but a universal one will work fine.
    Info copied and pasted from manufacturer's website:
    Features & Benefits
    Affordable 10/100 Switching
    Are bandwidth-intensive applications slowing your network to a crawl? This economical entry-level switch, designed for larger or growing small offices, speeds database, accounting, and multimedia applications and file exchange. It excels at connecting high-speed servers, a backbone, or power-user workstations to a small-office LAN. Or use it to add more Fast Ethernet hubs to a workgroup. "Plus" switches offer advanced features such as auto MDI/MDIX on every port to simplify installation, and traffic prioritization to enable real-time video and audio applications to run over the network.
    With plug-and-play installation and no configuration needed, the switch fits easily into your unmanaged network
    Automatic MDI/MDIX on every port makes expansion easy by eliminating most common cabling errors whether the port is connected to a server, PC, or another switch or hub
    Sixteen autosensing ports automatically detect the speed of the attached device to maximize network performance
    Traffic prioritization ensures that real-time applications (such as video and audio) take priority so they can run effectively
    Full-duplex feature supports two-way data transfer, doubling the effective bandwidth of the network
    Compact, fanless design ensures quiet operation in small office spaces
    Connectors at rear help reduce cable clutter
    FCC Class B switch is approved for use in home office and small office environments
    Hewlett Packard AdvanceStack Hub-8E - -
    $45
    I can't find the power adapter to this, either.
    Info from link:
    8 x Ethernet 10Base-T, Ethernet 10Base-2, 10 Mbps, 1.3 lbs, 7.5 " x 5.2 " x 1 "
    The AdvanceStack 10Base-T Hub-8E is the base model in the entry-level series of hubs from Hewlett Packard for the small office, small business, or small workgroup. The AdvanceStack family of hubs offer expandability and value by allowing you to purchase what you need now with the option of adding new functionality as your network needs change.
    This model has 8 RJ-45 10Base-T ports and allows cascading to easily expand (use one of the RJ-45 ports to connect to another hub). It also has one BNC thin coaxial connection for connection to a backbone that you can also use to connect to other hubs. The AdvanceStack 10Base-T hubs support Plug-and-Play for easy installation and use. There are also LEDs that aid in diagnostic functions, including Activity, Collisions, AUI/Xcvr, Per Port Status, and Power that provide quick hub status checks as well as troubleshooting support
    56x CD-ROM IDE Drive
    - - $5
    It does it's job like it did when I bought it a few hundred years ago.
    Info from link:
    If it is time to replace that worn out and tired CD-ROM, we have the perfect solution for you! This 56x CD-ROM IDE drive provides quick and easy access to applications, games and more! Get one today!
    Features/Specifications:
    • 56x CD-ROM IDE Drive
    • General Features:
    • Beige Bezel
    • 56x maximum read speed
    • 128 KB buffer
    • Access Time: less than 120 ms
    • IDE interface
    • Front Panel Features:
    • Headphone in jack
    • Volume control dial
    • LED activity indicator
    • Emergency eject hole
    • Play/Forward button
    • Stop/Eject button
    • Rear Panel Features:
    • Digital audio connector
    • Analog audio connector
    • Device jumpers
    • IDE interface
    • 4-pin power connector
    • Power Specifications:
    • 5V - 1.2A
    • +12V - 1.3A
    • Regulatory Approvals:
    • FCC
    • CE
    • TUV
    • Semko
    • Nemko
    • Demko
    • Femko
    Package Includes:
    • 56x CD-ROM IDE drive
    • Mounting screws
    • Install guide
    Additional Information:
    • Notes:
    • Model: BCD G621D
    • Product Requirements:
    • IDE controller
    • IDE cable
    • Available 5.25-inch drive bay
    • Available 4-pin power connector
    Saitek ST290 PRO Joystick
    - - $15
    Works perfectly.
    Link shit...:
    ST290 Pro Joystick
    The ST290 Pro is the adjustable stick to give you the gaming edge. The ST290 features a three-position palm rest that provides the most comfortable experience to suit all hand sizes, and which is reversible to support both left- and right-handers.
    An important consideration when using a stick is rudder control. Most other sticks at this level don’t have a rudder control but the ST290 Pro features the 3D rudder twist that gives you much greater control over your aircraft, whether taxiing or side-slipping to land in a cross wind.
    • The adjustable stick to give you the gaming edge.
    • Three-position palm rest for total comfort; adjustable palm rest provides the most comfortable experience to suit all hand sizes, left- or right-handers.
    • Rapid-fire trigger
    • 5 fire buttons
    • 8-way ‘point-of-view’ hat switch
    • Lever throttle
    • 3D Twist Rudder control
    • Single spring gimbal mechanism
    System Requirement:
    Connectivity: USB 2.0
    Windows XP, XP64 and Windows Vista (all versions)
    This product is fully compatible with Windows Vista. However, the SST software and drivers on the accompanying disc will only work on XP. If you are using Vista the latest drivers and SST software can be downloaded from our Drivers and Software section of manufacturers website.
    Siemens SpeedStream 4200 DSL Modem
    - - $15
    Works perfectly.
    I have an ethernet or USB cable if you need it.
    InterAct V3 FX Racing Wheel 2 w/Pedals for Playstation 2
    SOLD
    Athens
    Sale pending on steering wheel and pedals.
    Athens
    Discount available!
    Athens
    up
    Ghost AirMax95's Avatar
    On a Plane
    Joysitck......meet @ MOG?
    Athens
    PM'd
    Athens
    Up
    Athens
    OBO
    Athens
    Athens
    Up.
    Athens
    Bump
    Athens
    Mother fucking bump.
    Athens
    Up
    Athens
    Bump
    Athens
    ttt
    Athens
    ttt
    Athens
    Bump
    Athens
    Athens
    Prices are OBO!!!!!!!!
    Athens
    ttt
    Athens
    Name your own price!
