Thread: Best Kind of Harness??
    FUK IT! bowdown201's Avatar
    Next Door
    Thumbs up Best Kind of Harness??
    IM USING THESE LINKS AS REFERENCE THAT IS ALL. But just wanted to get some suggestions from people who have used/use them and which they like better.
    One like this..without the crotch strap
    http://cgi.ebay.com/ebaymotors/Black...Q5fAccessories
    Or one like this..
    http://cgi.ebay.com/ebaymotors/4-Poi...Q5fAccessories
    Athens/Memphis
    If you are just autocrossing, then a four point harness should be OK. However, if you are doing any kind of racing where there is a higher risk of a crash, then I would get at least a 5 point harness.
    Also, make sure that the harness that you are buying is properly certified. You don't want to skimp on something that could be saving your life.
    UGA: Everybody is laughing at us this year.
    Next Door
    well it really wouldnt be for autocross or anything. 1 would be for drifting and 1 would be for pretty much daily use.
    The first BY FAR, DO NOT GET SOME CHEAP LITTLE SKINNY BELTS.
    The crotch strap aka submarine belt helps A LOT and makes the harness work properly, either way, without a roll cage or bar or SOMETHING you are taking risks.
    Next Door
    well I have a roll bar so im good on that. and im more than likely going to get the 5 point with the 3 inch straps but just wanted some feedback on how they felt and what not
    Ok good, and do the wrap around mounting, do not bolt them in.
    They FEEL good, when racing lol, on the street you will get sick of strapping in very quickly, plus the lack of movement, I say just leave the stock belts, mount the harness, and wear it when on spirited drives and such.
