Results 1 to 4 of 4
Thread: speaker wiring question..
    ALL CAPS JITB's Avatar
    Default speaker wiring question..
    So today i decided to pull my speakers out of my protege which isnt working, and put them into the 929. because they are blown, I have a aftermarket radio, running thru the factory amp. My speaker wire for each speaker has a 4 wire plug, do i need to connect all 4 or just the 2 + and -? i started but it started to rain so i quit for the day.. Would just connecting the + and - be ok?
    And another question.. Should i just go get some speaker wire, and just hard wire all speakers straight from the radio, and bypass the factory amp? Would it save the hassle im gonna have with this ancient factory amp when i add a sub, and amp?
    co-lame-bus
    its best to bypass the factory amp when you add in an aftermarket speaker setup, headunit, and amp/sub ... just my gl and just pm me if you have any questions on it
    Quote Originally Posted by hatch22
    so sounds like ive got a fun filled day of running wires tomorrow...
    02 WRX patrick4588's Avatar
    warner robins
    make sure to run the speaker wires on the opposite side of the power wire. go ahead and plan out what you want to do with the sub/amp combo that way you wont have to re run everything later.
    GCO Member
    NRA Member
