Thread: Wire Question!
    Default Wire Question!
    well i still have this stupid spark problem that i stated in the other thread. this is a picture of the clip going into the ignition coil from the harness. the question is, what are these wires? im sure one is power of course, but im not sure which one it is. and what would the other be? thanks!
    Southside Ridin HATCH
    bump for looking...
    Hope you get help!!
    ALL CAPS JITB's Avatar
    take another pic, but show more... one is a ground i believe. Whats wrong with your ignition?
    i read your thread.. Did u check the ground wires to the ignitor? there is a bolt that grounds the disty/ignition everything, right next to the distributor. It may be loose, or stripped out, if you have taken it out. And the car wont start without it, or if it maybe loose. i found that out the hard way..
    i posted in your thread on Cp.. i have an ignitor on my harness from my protege, sittin in the garage. That you can try out if you need before you buy one.. But they arent too much from the pullapart, and i do believe they are all the same between the bf/bg..
    i know which one your talking about. that one is fine im pretty sure. i did take it off once and as you said, nothing at all.
    ill try to get another picture up here shortly, just got back from autozone.
    im double posting but oh well. lol
    i looked in the haynes manual for the 1990 protege and it says the yellow/blue wire is coming from the igniter in the dizzy. so maybe possible i could just need a new igniter.
    but its $284.99 before tax!
    up for more pictures! sorry to rush but this is my primary car. i need all the help i can get.
    reps for any help or bumps
    Middle, Ga
    Damn Louis, did you turn white?! lolol Thats not a black hand in those pic's. lol.
    Bump for a friend.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Quote Originally Posted by DeeAOne
    id try to get to a pullapart to find an ignitor..do u have a timing light to check ur spark?
    Bump for a friend.
    im light skin, ass. lol
    and yeah jitb, im going to head to the junkyard sometime soon to see if i can find one. i maybe drive up that way to the better ones though. the gas would be worth it if i could save that much.
    cool.. there are a few 323 bgs in the yard on buford and moreland last time i went. they have the b6 sohc... if u cant find any bfs.. im not 100% if mine is the same from the protege.. i thought it looked the same, but i have my doubts now..
