Results 1 to 22 of 22
Thread: 99 OBD2 GSR SWAP INTO MY 93 OBD1 DEL SOL
    Certified Gearhead kbiais's Avatar
    conyers
    Default 99 OBD2 GSR SWAP INTO MY 93 OBD1 DEL SOL
    BEFORE I BUY THIS SWAP IS THERE NETHING I NEED TO MAKE IT WORK IT BESIDES CONVERTING TO MANUAL IT COMES WITH ECU , WIRING HARNESS , AXELS , TRANS AND ENGINE SHOULD I BE ABLE TO JUST PULL MY D AND DROP IN THE B AND PLUG AND PLAY THANKS ALL KNOWLEDGE IS APPRECIATED
    What motor is in your car now? You can't use the harness on the GSR it's OBD2, You need a small list of parts to make it work.
    All 92-95 is Obd1
    Obd1 Dizzy (gsr)
    Obd1 Alternator
    Obd1 Vtec harness (ex model civic) or (Delsol S)
    Obd1 ECU (P72)
    Those are just some things that come to mind but will get your started in the right path..
    conyers
    YEA I GOT A D15 IN IT NOW
    COULDNT I REPLACE MY HARNESS WITH THE OBD2 HARNESS THAT COMES WITH THE SWAP
    conyers
    R U SAYING I NEED TO GO WITH A 92 - 95 GSR OBD1 B18C IN IT INSTEAD OF THE 99 GSR OBD2
    Easy and cheaper to swap in the OBD1 GSR,
    Quote Originally Posted by kbiais
    use your current harness and add the wires for vtec.
    LAWRENCEVILLE
    the obd2 integra harness plugs right in to your delsol the obd2 harness is fine! you will need a obd1 gsr ecu and will need to wire in vtec and the knock sensor. thats all
    Hella stock member!
    His harness will not plug into the dizzy or alt..
    Quote Originally Posted by silversol
    Since when, His car is a 93...
    LAWRENCEVILLE
    the integra harnness plugs that plug into the car are the same from 94-01 and they are the same as 92-95 civic and 93-97 delsols plugs! useing the obd2 harness will use the obd2 dizzy and alt will not be any problem. I have done this swap many times I know it will work i had a 98 gsr swap in my 93 sol. and used this combination
    Hella stock member!
    So your saying it has a single plug or dual plug on the driver side?
    LAWRENCEVILLE
    Quote Originally Posted by 1civic
    i think you are thinking about the 96-98 or the 99-00 civic harness which will not work in any other car but a 96-98 or 99-00 civic. but yes the obd2 integra harness will work in 94-01 integra 92-95 civic and delsol's. with his 93 he will need a obd1 ecu and run the vtec,knock, wireing.
    Hella stock member!
    Delsol being the only car this works on.. Umm. I'll make not of that, Never tried it..
    LAWRENCEVILLE
    It will also work on 92-95 civics with a obd1 ecu
    or a 94-95 integra with a obd1 ecu
    Hella stock member!
    Silversol is right. My friend has an obd2 integra harness in his obd1 civic right now.
    Sol, I had to go look...lol. The harness on my hatch is from a Delsol but the Delsol had a swap and guess what it is? lol
    Later!!
    OBD2 Engine Harness (since in OBD1 CIvics and any integra they clip in on the shock tower) should work and allow you to use the standard distributor.
    I was with bobby for a min till i thought about it. Easy to get confused cause when you see OBD2 HARNESS into OBD1 you automatically think about the problems the OBD2 CIVIC harnesses have, not the integra.
    Quote Originally Posted by Vteckidd
    I had to go look at one of my cars...lmao!!
    conyers
    preciate it fellas
    conyers
    so exna the obd2 ecu for a obd1 ecu and it should work
    Yes, But you also have to add wires for Vtec, Knock Sensor..
    SOUTHSIDE
    i had a 2000 gsr swap with the 2000 obd2 harness on motor and pluged right into the 93 civic all i wired was knock, vtec, and that little blue wire from the dizzy to my cluster so i would have rpm
    conyers
    coo well it was either find out hoe to do it or go get this obd1 gsr with auto trans they r both around same price range just not sure if i wanna swap out for a manual yet thanks again guys all help was greatly appreciated
