Thread: headlights problem
    PROJECTjdm project_EM1's Avatar
    Stockbridge, GA
    Default headlights problem
    ok so the problem is my passenger low beam went out when i was at work dont know why but i think it didnt have any power to it.
    btw i had my fogs drawing power from the low beams if thats helps
    so later on when i was getting off work my passenger high beam went out and blew the fuse so i changed the fuse.
    but the high beam still wasnt comming on but low and be hold the low beam came back on it wasnt the bulb .
    i tested it on the other side to check and it work both high beam and low.
    so my question is what could be causing the problem, could it be that i was getting power for my fogs directly from the headdlight harness or what.
    SoLow OutKast
    92 Civic Lx Ferio - sold
    94 Civic Dx Eg- insurance totaled
    93 Civic Si Eg6 - stolen/and striped(f**king thieves)
    00' Boosted Milano Red EM1- DD
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    try checking the hi beam and low beam power at the connector. check it with low beam on and high beam on. check power to ground
    98 Acura Integra LS-DD
    ??????????????????-project
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    what do you drive? I would take the fogs off the headlights and wire them up with their own power like they are supposed to be. Thats probably the reason you are having problems with your headlights
    Stockbridge, GA
    Quote Originally Posted by oneSLOWex
    i drive an em1 but i had it wire to the headlight for awhile now it just happen when i swap my stock headlights back on.
    i would wire them up with their own power but the harness i recieve was short so i had to adjust, but where can i wire them to so i wont hav a problem
    SoLow OutKast
    TALKING ROCK, GA
    Quote Originally Posted by Nfamou5
    parking lights....
    Stockbridge, GA
    Quote Originally Posted by b18ej1
    parking lights....
    yea i just did that when i called my buddy and asked hiim where he wired it
    hope it doesnt blow my corners this time
    low beams are working but passenger high beam is not seems to me it has no power
    so im assuming there is a short somewhere
    SoLow OutKast
    Low-n-Slow iEvo's Avatar
    Gnett
    i would try disconnecting the fogs and see if that fixes anything
