well basically my my questin is does it matter which 3.4 gm i get the 3 bar from or can i get the one that is required on any 3.4 gm that i come across with the required sensor...
thanks in advance
thanks in advance
AC Delco part numbers 213-1562 or GM 12223861
and what models does that one come on and thanks again for the feedbackOriginally Posted by 1civic
1989 turbo T/A..
Haven't kept the info around but most GM's use 1 and 2 bar maps..
Google the part numbers I posted, you will find a ton of info..![]()
Instead of just debo'in one off a car, just go to summit, etc ask for the part number listed, it will be just as cheap, and you will for sure get a 3 bar, and not a 1 or 2 bar...
lol....i asked because we have a couple of gm motors at my job that were pulled for other problems so thats why i asked free out weighs paying anyday and it still has the harness on it so theres my pig tailsOriginally Posted by EmminoDaGreat
true, im not much on used map sensors tho, do you have a built motor, if not why do you want to run more than 12 psi, if you do then I have the answer already...lol...
pmed...![]()
ok also now that i have found the sensor where would i start find the pigtail
thansk a whole lot man... reppedOriginally Posted by 1civic
If you get it from GM you can get the pig tail.. Also I think MSD sells it with a Pig tail..![]()
