Results 1 to 3 of 3
Thread: 5 Lug Conversion....can you recognize what it fits???
    M.T.4.L. noridetoolow's Avatar
    Columbus, GA
    Default 5 Lug Conversion....can you recognize what it fits???
    Ok...so I have a deal lined up for a 5 lug conversion, the guy got it with a bunch of JDM motors he ordered a while back. He has no idea what they fit. Here is a pic, best I have but it should be enough....I CAN email a larger pic if by some chance someone really wants more detail.
    So.....do yall have a clue exactly what this would fit? I assume Civic or Integra but, what years, model, etc??
    If they dont fit my car...Ill just post em up for you guys to buy.
    2000 EM1
    1998 Tacoma
    ...bagged.....in the process of a body drop
    It looks like it is off of a 96-00 CTR. If I see it correctly the upper a arms bolt comes in from the side and the lower control arm is stamped steel and has the six sided rubber bushing.
    It will bolt directly to 96-00 civic chassis with everything there or if you have an eg or dc chassis you can use your stock control arms with the front spindles, rear swing arms and brakes. I'm not sure about the axles but I believe CTRs are 32mm, the same as usdm civics and integras.
    Columbus, GA
    Good stuff.....I plan on going and picking this stuff up this weekend and will probably just post it up on here. Thanks
    2000 EM1
    1998 Tacoma
