Results 1 to 18 of 18
Thread: Car shut off at a light
    AEM_integra
    macon
    Default Car shut off at a light
    so i was driving to the bank on zebulan when my car cuts off at a redlight... wont crank back up... its gettin towed back to my house right now and we did some of the basics before we called checked if the fuses were blown and fuel pump still works and i have a full msd ignition on it so i dont think its that... anyone have any ideas... its a 94 del sol vtec
    Senior Member G.C's Avatar
    Forgot
    take the msd out. it's nothing but problem.
    We need more info. what happens when you turn the key?? is it trying to crank? or it doesn't do anything. double check ALL your fuses too.
    :idb:
    West palm beach
    I would start with swaping that MSD for stock and go from there...
    NO ADVERTISING
    -IA MANAGEMENT
    Slow children at play Meatball546's Avatar
    Apr 2009
    Marietta/Cumming, GA
    Could be a cam or crank position sensor.
    IA Member 2.0lef_itbs's Avatar
    mission bc
    so what your saying is you've got fuel,you must have air,the last thing you should check is spark(would have been the first cause msd is shit) imo
    4 things you need are
    air
    fuel
    spark
    and timing(if you loose a belt i just spins really fast maybe pop some valves aswell)
    Quote Originally Posted by Meatball546
    if those sensors are gone usually the car just runs in limp mode.super rich doesn't it.
    everywhere & nowhere
    Check the dizzy wires --- don't uninstall the MSD until you know that it's the problem. Usually heat kills those wires near the dizzy over time.
    Scottish Scotsman's Avatar
    on the road to recovery
    lose the msd and go from there
    AEM_integra
    macon
    ya its the msd ignition so im taking it off in the morn and going stock
    Titties!!!
    if one of those went there would be a CEL on and the code would be stored.
    did the Check engine light come on?
    Apr 2009
    The check engine light is usually on with the ignition switched on and the engine off. He hasn't been able to start it, so we can't know if the CEL would stay on while it's running.
    I know in BMWs, if a cam sensor goes, it may run; just very poorly with very hard starts. The crank position sensor is usually where electronic ignition systems get their references from. I don't know about Hondas and if they use electronic ignition modules or not. If they do, a failed crankshaft position sensor will probably shut it down.
    AEM_integra
    macon
    no CEL
    its my distributor rotor chipped up and burnt
    getting a new one tomorrow
    soooo worth the $40 tow for a $15 part
    hustler ksniperfox's Avatar
    lawrenceville
    Quote Originally Posted by 2.0lef_itbs
    air
    fuel
    spark
    you need a few more things other than those..and they are the main ones.
    compression
    combustion
    lawrenceville
    cause older hondas have those.....
    could be a lot of things. youre just stabbing in the dark.
    AEM_integra
    macon
    it was the distributor rotor button its starts and runs now... timing belt is loose now so i needa tighten it but i cn get to it
    Quote Originally Posted by turbo_teg
    Well there's your problem.
    West palm beach
    what do you mean you cant get to it ?
    NO ADVERTISING
    -IA MANAGEMENT
    Apr 2009
    Cool. Glad to see you're on the road again.
    earth ????
    i had msd on my car i took it off my car its usless unless you maken over 350 hp so any way same thing happend to my car was the coil. get another dizzy problem fixed !
