Thread: max hp
    1carNfrontOfu
    Default max hp
    What's the "safest" max hp on boost can an ls block hold before you must sleeve..Just curious....
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by LSblaze
    What's the "safest" max hp can an ls block hold before you must sleeve..Just curious....
    There is no exact number but with that R/S ratio and piston size, I wouldn't push past 350. You always hear 450 etc. but they are treading on very thin ice.
    Morrow 30260
    But other things factor in, like if stroke has been changed, tuning, piston weights, if the block is posted and or block guarded.
    1carNfrontOfu
    nothing done to internals....just bone stock
    Morrow 30260
    Well, in that case, the sleeves are the least of your worries. Piston ring lands, or rod bolts will fail way before the sleeves.
    Morrow 30260
    And if by some miracle the rod bolts don't stretch, the rods will bend/break shortly after.
    1carNfrontOfu
    Thanks for the info...I was just curiuos to know how far I can turn up the boost before I decide to do the internals.
    1carNfrontOfu
    Thanks for the info...I was just curiuos to know how far I can turn the boost up before I decide to build the motor.
    stock internals i say 100whp over stock and it stays a reliable daily driver. the further you go the less reliable it becomes. i've tuned some to 150whp over stock w/o probs, but you're rolling the dice. with rods, pistons, headstuds-the sleeves are good for 400-500whp on a good tune...i usually say 400whp to give yourself a good margin of error. i've tuned a few on stock sleeves past 500whp that held fine, but i wouldn't expect much if you go that far.
