Results 1 to 29 of 29
Thread: ** I Just Got New BuddyClub Spec V Extreme Cams**
    slow but clean slow01's Avatar
    SoUtHsIdE
    Default ** I Just Got New BuddyClub Spec V Extreme Cams**
    HEY if anyone on here ran these cams please PM me and let me know how they did thanx
    B ENGINE CAMSHAFTS SPEC
    Buddy Club Racing Spec Cam Shaft B16/18 Spec V (pair)
    [img]images/products/p_BC05-RS5CMH-B.jpg[/img][img]images/pixel_trans.gif[/img]Click to Enlarge[img]images/pixel_trans.gif[/img]
    • [img]images/products/t_BC05-RS5CMH-B.jpg[/img]
    • [img]images/products/t_BC05-RS5CMH-B2.jpg[/img]
    RACING SPEC V EXTREME CAMSHAFTS
    Developed, tested and proven by Buddy Club's own race teams and engineers, the Racing Spec 5 camshafts are absolutely the most aggressive design in camshaft technology available today. Utilizing Buddy Club's patent pending lobe forming technology was used to increase low to mid-range torque and yet have an astonishing 12.8mm lift for explosive high-end power! These cams do not sacrifice low end power for top end gain! This is unlinke anything you have experieneced before. Available and in-stock now! MSRP: $728/pr- Designed for racing engines with high compression (normally aspirated)
    -12.8mm intake lift and 11.8mm exhaust lift for top-end power
    - Patent pending lobe forming technology for low to midrange power
    - SMOOTH CONSTANT POWER THROUGHOUT THE ENTIRE RPM RANGE!
    - (From idle to 9500RPM)
    - Requires Buddy Club high compression valves, valve springs, and retainer set
    - At least a 12.5:1 Compression Ratio is recommended
    - Professional installation and calibration is highly recommended
    - ( Additional piston valve clearancing is required)
    Buddy Club's patent pending lobe forming technology allows engineers to create uniquely shaped cam lobes that unleash power from areas that other camshafts are simply not capable of finding. Other brands try to approach Buddy Club's cam profiles, but can never surpass it, nor equal it.
    When you choose Buddy Club camshafts, you will be proud to own what years and years of racing data and experience have guided us to develop. We offer exactly what we use to win race after race and there simply is no compromise. We believe in our own products 110%
    Buddy Club camshafts are designed to produce increased power all throughout the RPM range of your engine from idle to redline! With Buddy Club cams, you will not find a dramatic power surges, even when VTEC transitions. What you will find is an extremely smooth and predictable power curve that you can use to power in, through, and out of each corner and still have what it takes to dominate the straights!
    With Buddy Club, there is no trial and error...
    SPEC V
    *Dyno Tested
    268HP
    233TQ
    B18C1 Engine
    $728.00
    o1 em2 coupe
    92 eg4 hatch
    92 eg8 sedan (traded)
    88 ef2 hatch (sold)
    93 eg1 del sol
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    What motor are these going in and what specs?
    SoUtHsIdE
    SPEC V
    *Dyno Tested
    268HP
    233TQ
    B18C1 Engine
    TIMING
    DURATION
    VALVE LIFT
    VALVE CLEARANCE
    1mm OPEN
    1mm OPEN
    INLET
    35° BTDC
    52° ABDC
    312°
    12.8mm
    0.007
    1mm OPEN
    1mm OPEN
    EXHAUST
    62° BBDC
    32° ATDC
    306°
    11.8mm
    0.008
    o1 em2 coupe
    92 eg4 hatch
    88 ef2 hatch (sold)
    93 eg1 del sol
    Hopefully you don't put them in your DD... lol
    Out the game again!!
    southside of the border
    Quote Originally Posted by 1civic
    thats probably his plan
    Soon!!
    SoUtHsIdE
    Quote Originally Posted by allmotorX
    and this is comming from someone with no car lol
    o1 em2 coupe
    92 eg4 hatch
    88 ef2 hatch (sold)
    93 eg1 del sol
    Miss my Civic.
    Hahaha...You should probly stop puting Spec V in front of everything. You are most likely making people think you are talking about a sentra.
    everywhere & nowhere
    This better be about Sentras or I'm not interested.
    But in the end it really doesn't matter... domestics are better than imports.... there has never been a fast import in the entire history of Earth.
    Quote Originally Posted by slow01
    dont let the sig fool ya
    Soon!!
    It's a Civic with a Sentra Spec V motor ... j/k. lol
    they are pretty much PRO2/3 Copies. My buddy made over 250whp with them, but they were on a BUILT MOTOR with ITBs
    Good luck getting these mofos to idle.
    your moms house
    they actually idle fine even with itb's.
    mike's right they are about the same specs as the skunk2 pro 3 cams. the cams actually degree out bigger than a set of pro 2's and the lift is close to the pro 3's. these cams have massive low lift duration on the primary lobe before vtec, unlike the skunk 2 pro 2 & 3 so they cause serious valve to valve clearance issues down low. so you have to sink to valves into the head .015 to .020 thou to solve the v2v clearance issues and make sure they are degreed in to specs
    cliff notes if you don't know how to degree in cams and don't have a built engine with ported head etc etc don't even bother with the cams. you will end up with holes in your pistons from grenading the valves and your next post will be spec v cams caused me to blow my engine.
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    i love it how people buy something then ask how they preform...
    kinda pointless to ask now.
    SoUtHsIdE
    Quote Originally Posted by all-mota
    i know what i need to do to make it work i just sold a built b20 with crower 403's and it made good power how hard was the tuning on that set up
    o1 em2 coupe
    92 eg4 hatch
    88 ef2 hatch (sold)
    93 eg1 del sol
    Prob a stock B16. LOL
    How "built" are we talking was this setup??
    LOL 403s are not PRO3s or anywhere near it
    SoUtHsIdE
    Quote Originally Posted by Homer Simpson
    for the price i paid for them everyone would of bought them i just wanted to know how they ran thats all
    o1 em2 coupe
    92 eg4 hatch
    88 ef2 hatch (sold)
    93 eg1 del sol
    ASAP AssHole WTF?'s Avatar
    Woodstock/Kennesaw
    quite bashing let the people who know what there talking about like vteckidd talk and leave the bs out
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    Quote Originally Posted by WTF?
    what the hell did you just say?
    :english:
    SoUtHsIdE
    thank u i was just asking
    o1 em2 coupe
    92 eg4 hatch
    88 ef2 hatch (sold)
    93 eg1 del sol
    your moms house
    tuning is never the problem with any setup. i told you exactly what you needed to do in my previous post.
    "the cams actually degree out bigger than a set of pro 2's and the lift is close to the pro 3's. these cams have massive low lift duration on the primary lobe before vtec, unlike the skunk 2 pro 2 & 3 so they cause serious valve to valve clearance issues down low. so you have the sink to valves into the head .015 to .020 thou to solve the v2v clearance issues and make sure they are degreed in to specs
    cliff notes if you don't know how to degree in cams and don't have a built engine with ported head etc etc don't even bother with the cams. you will end up with holes in your pistons from grenading the valves and your next post will be spec v cams caused me to blow my engine"
    Dude relax - we are just taking it easy on you really --- post this on HT and see what you get---- you'd come back here w/ your tail between your legs.
    Building a seriou N/A engine takes serious knowledge and serious research. Why not post what setup you have (or want to have) and there will be some guys to direct you along the way --- it's easy to tear shit up let me tell you.
    D0 W3RK RedEj8's Avatar
    Macon
    If you know how to degree cams and clay a motor then you should be good...
    General Tech Hater
    Quote Originally Posted by RedEj8
    sir.. those who still rock monsoons need not post in any tech areas..
    Macon
    Don't hate on my Monsoons. You know you want them on the Acura.
    General Tech Hater
    you mean the caprice wagon
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by Sentra
    Thats what I was thinking. I was like, when did a Sentra come with a B16?
    -Ant.
    The Carbon Fibered R6
    Show me this 268HP/233TQ B18C1. When, where, and who?
