Results 1 to 26 of 26
Thread: Vtec doesnt work!
    Cobb/Cherokee County
    Default Vtec doesnt work!
    Problem fixed thanks all
    Scottish Scotsman's Avatar
    on the road to recovery
    did you plug the vtec solenoid back in?
    do u have a good ground going to the solenoid?
    JDM TYTE AnthonyF's Avatar
    I am not 100% on this, but I could have sworn if there was a coolant code, vtec wont work either.
    -Ant.
    The Carbon Fibered R6
    Turbo City USA
    If there is any CEL, it won't work.
    barrow county
    x2 that and check if you have enough oil
    alright that code in the haynes manual tells me to check the green plug thats going to the vtec solenoid. I had a check engine light on before and vtec worked??? Then I tried to see if i could reset the ecu and when i pulled the fuse the whole car died? Help plz.
    Now, i do believe there are 2 connecters VERY close to each other than can plug it one another. Make sure they are correct.
    -Ant.
    General Tech Hater
    -Ant.
    truth! the plug for the oil pressure switch in the VTEC solenoid will be somewhat close to the ECT sensor.. well it is on D and F series, not sure with B series..
    What plug am i suppose to check?
    this pic is off the web
    Attached Thumbnails Attached Thumbnails -68954646oi3-jpg
    does the black wire on the green plug go into the harness?
    in dabuilding
    green plug is the vtec pressure switch and the black one is wat engages vtec but code 6 is coolant temp sensor that is in that pic too its the grey plug under the vtec solenoid pull it off and get a new sensor and check all grounds gl man hope this info helps
    Yeah black wire runs to the harness.
    Will check.replace coolant temp sensor tomorrow.
    Can that cause vtec not to work?
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    if these things arent working or operational neither will you vtec. 1. up to operating temp which you wont be if you have a code 6 coolant temp code. 2.speed sensor working. 3. throttle pos sensor working. 4. oil pressure to v tec pressure switch. 5.spool valve or vtech solenoid and last 5.rpm window switch in ecu or tach. vtec presure switch code is 22 and solenoid is 21. in this chilton it says all these must work or be at normal operation temp coolant wise for vtech to engage. just get a coolant temp sensor and take off the ground for 10 secs and reset your ecu.hope this helps
    Quote Originally Posted by turbob20
    fixin to get a new coolant temp sensor today hopefully all my problems disappear. i tried resetting my ecu the car just died on me
    everyone who has replied with a helpful answer will be repped
    if problems still occur i will let you guys know!
    in dabuilding
    Quote Originally Posted by GaGen2Teg
    u gotta reset it while the car is off man
    couldnt have said it better myself.
    not ALL CEL will disable VTEC. Only VSS, COOLANT Temp, etc listed above will.
    Titties!!!
    -Ant.
    yep the car has to get to normal opertating temp(basically warm up) for VTEC to work. make sure the solnoid is plugged in and check the coolant temp sensor which should also be somewhere in that area. Ant is on the $$ on this one. when my car is cold there is no VTEC. as soon as it warms a lil it works. check the code and fix it man if you need the coolant temp sensor get it, but you may just have a bad connection on the plug or not plugged in all the way. if i remember correctly can't these be stubborn at times while unhooking.
    Titties!!!
    Quote Originally Posted by Vteckidd
    amen a p0420 code on my car and VTAK still screams. lol
    found the problem! damn wires where loose near the plug gotta splice and reconnect them!
    Titties!!!
    i thought that would be it since it worked before, those connectors can be stubborn since they have been on there a while.
    okay took the car out earlier check engine light came on. code is 19 lock up control solenoid???
    i do have a chipped p28 with a p30 map on it if that is any useful info.
    what does this code do and do i need it? i looked in my haynes manual and it didnt have this code for the integra. so whats the deal with this now?
    Titties!!!
    i have never heard of that but will try to get some info, my manual has info for obd-1 and obd-2 trouble codes.
    o forgot to put nvm its gone!
    Lockup control solenoid code is for an automatic trans.
    Titties!!!
    no wonder i wouldn't know that i have only had 1 auto tranny out of all the cars i've had lol.
    glad to see the CEL is gone.
