Results 1 to 10 of 10
Thread: Larsen Cycle RADAX engine - this is incredible.
    1010011010 Atlblkz06's Avatar
    Hell
    Default Larsen Cycle RADAX engine - this is incredible.
    Holy cow this engine is incredible! The Larsen cycle RADAX engine is an 8-cylinder, "2-stroke" engine that puts out 300 HP with an efficiency range of 45 - 54 percent, which far exceeds conventional engines. Mel Larsen has claimed that his engine has set the word record for in thermal efficiency. The engine works on EIGHT power stroke per revolution. The dyno chart on this thing should be crazy!
    Watch the VIDEO
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    goodshit
    Slow children at play Meatball546's Avatar
    Apr 2009
    Marietta/Cumming, GA
    Very interesting. I'd very much like to see a rough diagram of the motion of it though... The video sounds really vague about how the reciprocating motion is converted into rotary motion. It's a good idea nonetheless. I hope to see it in production some day.
    Hell
    Yea me too - but they explained it as a cam design. Think valvetrain - only backwards. The piston pushes on the gradient that you see - that rotates the output "disc" with the cam planes on it.
    Sandy Springs
    A Boxer-styled 8 cylinder?? Drop that bitch in a Subby!!!
    \m/>_<\m/ dorin48's Avatar
    Canton
    300hp and 900ftlbs on demand in a 220lb package... I'll take two please.
    Athens/ATL
    Sucks it was stolen... apparently Larsen died last year, and while in the hospital dying, someone broke into his shop and took the running prototype, all his notes and data about it, his tools... literally stripped the shop. A lifetime of work gone.
    It's incredible engineering. Absolutely incredible.
    Stang Mod slostang's Avatar
    Southside
    id like to see it run.
    when he says rotary cam, is that the same as any normal cam? It would make since because a cam rotates, but just wondering.
    Bender A. Rodriguez
    Macon
    Imagine a cylinder with what looks like rounded V's cut into its circumference. As the rods attached to the opposing cylinders goes front to back it has a mechanism that rides inside the V's. As this happens it turns the center drum, that's why it can spin either direction depending on which side is on its power stroke at any point in time.
    Ryan Reynolds
