Page 1 of 3 123 LastLast
Results 1 to 40 of 118
Thread: Btec Blowout Cell!! OBD0,1, and2 b16 parts, 92-95 civic and 94+ Integra Parts
    Default Btec Blowout Cell!! OBD0,1,&2 b16 parts, 92-95 civic and 94+teg Parts *STUFF ADDED*
    b16a2 Shortblock. Does not smoke or knock. Rings have maybe 2k on them. Bearings looking fine when i put knew rings in. Been sitting for about 6 months. (no knock sensor, pcv valve, or timing belt tensioner) sold
    B18 automatic tranny unknown milage but worked before i did 5 spd conversion on friends car. (torque converter and flex plate included) sold
    EG A/C setup (condenser, fans, relay harness, dryer, lines from firewall) everything except 2 lines that go to compressor. sold
    Extra A/C Relay harness $5
    2 cooloing fans for 4 civic. Might fit dc integra too. $10 each
    EXtra harnesses. 2 obd1, 1 obd0, 1 OBD0 engine and dash harness with fuse boxes and relays (some connectors missing but most of the prolly stil there. Neither are vtec i dnt think.
    $10 each
    Automatic Padals and shifter assembly (cotter pins and washers may be missing but the main parts and there. $20
    DC Integra Airbox (hose from t-body to filter MIA) $10
    1 OBD1 B-series A/C compressor bracket, 1OBD0 compressor bracket (1 of the obd1 brackets has broken bolt that can be drilled out but i didnt feel like it) $20 each 1 sold
    1 obd1 b16 exhaust manifolds, 1 obd0 b16 manifold (with 2 o2 sensors), 1 obd1 gsr exhaust maniold $20 each b18b sold
    1 DA dwn pipe (piece that bolts to bottom of manifold) $5
    4 b-series heat shileds, 1 91 accord f22 heat shield $5 each
    2 d-series intake manilfolds, 1 obd0 b16 intake mani, 1 obd1 b16 mani (not sure what sensors or left, and i think they all have t-body's) $20 each
    92-95 civic front control arms not for factory sway bar (upper and lower) $20
    92-95 civic rear control arms not for factory sway bar (upper and lower) $20
    92-95 rear DRUM Brake setup including parking brake cables (ford blud drums) $30 Pic on page 2
    92-95 civic hatch bumper supports with foam (front and rear) $10 each
    2 b16 cranks, 1 b18b crank (1 of the b16 cranks will need to be machined for oversized bearing) others should be fine just getting polished $10 for bad crank $30 for good ones. b18 crank sold
    2 obd0 b16 p/s pumps (big pulleys), 1 obd1 b16 p/s pump $20 each
    1 dc integra automatic rear l-bracketsold
    1 96 teg axle back muffler STOCK $20
    1 b16 p/s braket (upper and lower) sold
    1 Set of tinted dc taillights $15
    1 94 civic hatch washer fluid bottle with pump $10
    1 civic/teg rear mount with urethane insertssold
    1 integra drivers mount sold
    1 B16 drivers mount and post mount with nuts sold
    1 b-series top tranny bracket sold
    1 passenger side aftermarket projector headlight $5
    6 b-series intake manifold braces $5 each
    Misc timing belt covers $2 per piece
    3 header braces $2 each
    1 automatic dc integra intermediate shaft sold
    b18b head and intake manifold (caps, cams, and valve cover will be included but not pictured) sold
    94 civic hatch tail lights (i have the covers that make them all CF or all black so you can paint them) $10
    1 b-series a/c compressor sold
    1 dc integra automatic cluster $15
    1 94 civic cx cluster $15
    1 main relay $10
    1 OBD1 P75 manual ecu sold
    1 OBDO PR3 ecu sold
    1 Skunk 2 obd2a to obd1 conversion harness sold
    1 obd0 pm9 ecu $20
    1 225/35/20 kumho Brand New!! $75
    EXTRA STUFF!! Pics on page 2
    1 Nitrous Kit. Chrome bottle, 175 hp nos solenoid, 200 hp fuel solenoid, all lines, switches, and button. Bottle heater. Purge solenoid. All u need is to tap into your fuel supply. I got 10 extra jets im throwing in. sold
    APC Coilovers. One sleeve is missing lock spring. 2nd one from the left. I got 2 more coils to throw in bc i dnt need em. $20
    ***Some prices are negotiable. All parts are in Riverdales but i live in Sandy Spring. Some parts are dirty as fook (see pics for details). engine and tranny will have to be picked up in or close to riverdale unless you pay extra.
    wtf is up with my pics?
    Attached Thumbnails Attached Thumbnails -image_106-jpg   -image_107-jpg   -image_110-jpg   -image_111-jpg   -image_112-jpg
    Attached Thumbnails Attached Thumbnails -image_113-jpg   -image_114-jpg   -image_115-jpg   -image_117-jpg   -image_118-jpg
    more...
    Attached Thumbnails Attached Thumbnails -image_119-jpg   -image_120-jpg   -image_121-jpg   -image_122-jpg   -image_125-jpg
    server too busy my ass!!!!
    Attached Thumbnails Attached Thumbnails -image_126-jpg   -image_128-jpg   -image_129-jpg   -image_130-jpg
    last pics...
    Attached Thumbnails Attached Thumbnails -image_132-jpg   -image_134-jpg   -image_146-jpg
    f-ckouttahere. PRO®'s Avatar
    location?
    Quote Originally Posted by staysikwitit
    location?
    last sentence b4 pics start. "Parts are in riverdale". I live in sandy springs though.
    Sep 2003
    R12 or R134a on the EG AC stuff?
    r134
    PARTS ARE IN RIVERDALE. BUT I LIVE IN SANDYSPRINGS!!!
    Sep 2003
    r134
    I'm assuming no compressor since it's not in the pic, correct?
    Quote Originally Posted by 5spdfrk
    there is a compressor in the thread with a pic and a price
    1 b-series a/c compressor $30
    Thats the only one i have
    Sep 2003
    Ok, cool. Sorry, I missed that, it's been a long day already!
    its cool.
    IA Member boosted91rex's Avatar
    Athens,Tn Hickory,Nc
    Default need this
    pm back pleez
    Attached Thumbnails Attached Thumbnails -mount-jpg
    BK ALL DAY
    jess i need the ls crank buddy
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    in dabuilding
    if u come across an obd0 b16 under hood harness lmk
    otherwise bump
    all pm have been replied too. smokeyj ur pm's are full so u got no reply. also where im located has been posted in this thread like 3 times already.
    Quote Originally Posted by Da_unknown
    you dnt need no damn crank suckuh!! lol! you got my number.
    changes of possibly sold items have been made to list. And all pm's have been responded to. Make sure ur pm box is clear if u want a response. Thanks for looking.
    more parts pending.
    all sold parts have been updated. thanks to everybody that bought stuff.
    hey you still got the auto tranny?
    i want a ls crank...
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    Quote Originally Posted by LRT
    yep, still got it.
    Northwest Georgia
    good luck with your cail.
    Banned tippatone's Avatar
    College Park
    What a for sale thread....... Good luck
    i will be adding more stuff later tonight. stay tuned people! thanks again for looking.
    more...last uploads. For today.
    Attached Thumbnails Attached Thumbnails -image_156-jpg   -image_157-jpg
    latenight bump. check out the added parts. Dnt be scared, gitchew some!!! Holler
    more parts pending. make sure you check out the new parts and pics on page 2. prices added to bottom of list on 1st post.
    auto teg tranny, air box, and teg axleback all pending. will update tonight.
    PS: there is still nitrous in that bottle. buy this kit b4 i blow my civic.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    b16a2 Shortblock. Does not smoke or knock. Rings have maybe 2k on them. Bearings looking fine when i put knew rings in. Been sitting for about 6 months. (no knock sensor, pcv valve, or timing belt tensioner) $300
    Is this firm?
    IA's Transformer God obd1kenobi's Avatar
    29th Chamber
    bump!
    GeckoSquad / Skull Platoon
    Is this firm?
    had it posted for $400 so yes. the nitrous kit price aint too firm but dnt tell nobody.
    sold item and pending items that werent sold have all been updated. all pm's have been responded to as well.
    early morning bump. i might take the Nitrous off this thread bc its not just for Hondas.
    Nitrous has now been posted in the Parts for sale forum. Its $500 obo. But like i posted over there, dont get stupid asking will $250 work. Be realistic with your...bids. Holler!!!!
    And like everyday, all pm's have be responded to.
    Integra tailights are to be sold saturday. Coilovers are supposed to be sold then too but dude never confirmed if hes meeting up or not.
