Results 1 to 20 of 20
Thread: how much can i boost on my set up
    South Side Georgia
    Default how much can i boost on my set up
    Ok just finished my set up
    B18b1
    Je 81.5 bore 10.0
    ACL race bearing
    Eagle rods eagle crank shaft
    Golden eagle block guard
    P72 head
    Manely retainers springs valves
    Port and polished
    Comp 5700 cams aem cam gears
    Skunk 2 intake manifold ported to head
    Dsm 450 injectors with resister box
    1mm cometic head gasket
    Peak boost ram horn manifold
    50 mm tial bov
    38mm tial wastegate
    Peak intercooler
    Gt3057r ball bearing turbo
    Act 6-puck clutch and maybe a 7lb flywheel
    Now what kinda power could I get of this set up. Also
    I'm wondering if I should leave my gsr transmission or my type r
    Let me know your opinion guys.
    resize pic
    @thens!!!!! fools
    shot in the dark but im thinking anywhere from 375-425hp...if anyone else wants to correct me feel free
    South Side Georgia
    I haven't tuned it yet also where should I get it tuned
    Quote Originally Posted by jhadleyh
    resize pic
    Just because you have a block guard doesnt meen you can run mega boost, but 450 ish is the most I would do.... But the turbo you have probably wont make more than that....NEITHER WILL the 450 cc DSM INJECTORS... which will yield maybe, 300 whp before being completely useless.....
    My only question to you is why buy all these nice parts, and then get 50$ injectors?
    South Side Georgia
    What you mean yield
    resize pic
    Canton
    to yield= to make, or create. IE- this amount of ingredients will yield 8 servings...
    Try not. Do or Do not.
    increase your injectors or you'll be limited to 275-300. tuning=me @ mainstream.
    ^^^ great guy will get it done.also when i took my motor apart it wasnt sleeved and had a block guard i made 471 on 19 psi.everything still looked great except the main bearing.which i think a guy messed with my boost controller and tuned my boost way up
    revolution big mac's Avatar
    yeah man scotty at mainstream should be your first option. he tuned my cusins turdo acord back in the day! i have the dsm 450 on my car too. they really limit you alot
    Certified Gearhead SleepingTalon's Avatar
    Alpharetta, Georgia
    Need dyno tuning? Please see my sig. Like everyone has already said, you're gonna be fuel limited, but getting it tuned later on with bigger injectors, and more boost is an easy task. The turbo you selected is a great turbo for your setup though, and when it's all said and done, you'll have a lot of fun with it.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    also i dont see anything about a 255 fuel pump wich is also needed to get the extra ccs from those injectors in the first place,id go with some 750ccs. i can get you a hookup cheap for brand new ones let me know and ill get you the info.
    Northwest Georgia
    your block can handle 500 on race fuel, your turbo won't really go that high though.
    Why on earth did you put an eagle crank in there?
    yes with out the 255 its going to start starving after 7500 rpm
    South Side Georgia
    sorry i forgot to put the 255 walbro fuel pump i also have that
    resize pic
    LaFayette Ga.
    750ccs or 72lbs per hour and 500+ race gas as stover said. on pump look for around 400-450 depending on turbo piping and the tunner.talk to scottydb411.
    South Side Georgia
    resize pic
    i did 19 on 93 pump and did 471. i was gonna get it retuned on 25 until it messed up. but we thought it was a sleeved block and wasnt. but i would say you could do 22 on race gas
    Northwest Georgia
    I said the BLOCK can handle that power.
    I don't even think 750's will support over 500, atleast..i know i wouldn't do that.
    get some RC 750's and you will be set.
    sleeve me please?
    monroe
    i wouldnt go over 4-450 since your block is bored over a tid bit your at a higher risk of cracking your block
