Results 1 to 3 of 3
Thread: obd0-obd1 jumper harness pulled some pins out
    Default obd0-obd1 jumper harness pulled some pins out
    Hey my jumper harness has some broken pins. Was wondering what exactly these pins do. If so where to get replacement pins to resolder them back in.
    Hey, first day I drove my ls/vtec and the temp spiked real high on me. The car was not overheating so I'm sure it was the loose wire out of the temp sensor. went to crank it back up and nothing. No starter engagement, but I can hear the relays kicking in. I noticed that 3 pins broke off my obdo-obd1 harness. pin # C10, C12, ,C14, & C16 Doesn't look like it goes to anything. I ordered new pins, but I tried to bypass the plug just to get it cranking and still it does nothing.
    I'm really stumped here and I've tried my ls ecu and still nothing. I'm hoping when I fix the harness correctly that it will crank, but I'm not counting on it since I bypassed the plug and it still won't crank. The starter is good. Any help would be appreciated.
    Woodstock
    did you check for spark and fuel when you jumped the wires
    So I found out today that i own a "Honda Silvia"...
