Results 1 to 17 of 17
Thread: FFFFFFFFFFFFFFFFFFFFFFFFFUUUUUUUUUUUUUuu
    IA's Pedo-cord tdurr's Avatar
    Fayco
    Default FFFFFFFFFFFFFFFFFFFFFFFFFUUUUUUUUUUUUUuu
    well tonight i decided to change the oil in my moms 05 accord. Well turns out the fucking drain plug is stuck on like it was impacted by a dumbass at carmax so i spent about an hour stripping the bolt before i gave up. Fuck.
    That is all.
    /rant
    Save ur engines!
    carmax ftw
    Did you turn it to the left?
    Fayco
    yes. Using a variety of tools.
    Save ur engines!
    long dong silver hondaman050's Avatar
    dallas
    reverse thread.... lol
    new plug, new gasket, and some of these
    in dabuilding
    that sucks! new cars ftl...
    Quote Originally Posted by dabuilding
    so its not possible for the same thing to happen on a used car?
    Fayco
    bruce i gots 2 of the 3 things. But I dono if i can get that thing in there(no homo). I have like a 3 and 1/2 long by 2inch section behind the drain plug. fwd v6 ftl.
    Save ur engines!
    Stang Mod slostang's Avatar
    Southside
    yeah i was in a rush one time and i needed my oil changed, took it to walmart and these motherfuckers put red loctite on my drain plug. i feel your pain.
    in dabuilding
    use vice grips?
    ask DB4LYFE im really good at getting stripped bolts off......if u have one to replce it
    Southside
    use vice grips?
    thats what i used
    in dabuilding
    Quote Originally Posted by slovic
    thats what i used
    well when we were doing his swap one of the bolts holding the flex plate to the crank stripped out so i had to grind it down to make it square so i could get vice grips on it because it is very short and shaped like a bottle cap
    Lurker Brick's Avatar
    Canton, GA
    Get a box wrench one size below the size of the bolt. Placed it on the bolt and hammer it on all the way, use another wrench for leverage...loosen. Get new bolt.
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    that ish suck
    Fayco
    ^^ not enough space. I tired and couldnt get a hammer or anything in there to smash it on with.
    dabuilding, i did use vice grips. Ended up tearing groves into the bolt head.
    It really is pissing me off. I prob am gonna take it up to my school next week and attack it with a ziz wheel and a flat head or something.
    Save ur engines!
    Quote Originally Posted by tdurr
    Don't fuck up the pan! THen you will really be fucked.
    Dude, that socket set i posted works wonders. I use it at work to get fucked up plugs out all the time. You could bring it through and I'll get it out if you want. I'm in alpharetta tho.
