Results 1 to 4 of 4
Thread: Help Me Fix My Honda... (Misfiring Problem)
    Default Help Me Fix My Honda... (Misfiring Problem)
    Car is a 01 civic Ex. D17a2 with about 90k on the motor.
    I'm getting random misfire codes. Usually on cylinder #2, sometimes on 1,3 & 4 if i don't drive it for a few days. It has a jumping idle, but only after I reset the comp. It also has no power (which is a given), And it surges and backfires alot. Its worse during light throttle, and at tip in.
    I changed the plugs, swapped coil packs around, cleaned the tb, and ran some sea foam through it. Car still runs like crap, but now there are no codes.
    I don't think its the hg, because there is no coolant in the oil.
    I'm gonna try to find somewhere to do a fuel pressure test on the low low, cuz i don't have the tools.
    Any suggestions?
    u check timing
    u check timing
    Nope, My timing light grew legs and ran away when i moved. But i don't think it jumped timing, because last time it jumped timing I had to get a new motor.
    Quote Originally Posted by Bruce Leroy
    thats jumping a few teeth or braking but 1 tooth you will still have a motor but it will run like shit.
