- RAM going dead?
RAM going dead?
For some reason my comp can't handle counterstrike anymore, the mouse like freezes up in a way.. (if im moving it, it will stop moving for a second or two while the game is still going) My freind looked at the ram graph(?) thingie and he said it goes from working to 0% n then working again, i don't know whats going on and im not too good with computers. So any help is apreciated
throw that shit away, u goin to varsity?
Its a possibility but if ram was the issue it cause random freezes/spikes/crashes anytime not just during your game. How many dimms (individual chips) do you have? Usually the real sign of ram going bad is random crashes or blue screen o' death.
im not sure wat dimms are? but i have a 1gb stick?.. i dont get random crashes tho.. maybe its my vid card?
Go into your bios and see what your cpu temp is at, the most common cause of this ive seen is the fan going bad and the cpu overheating.
- Rep Power
- 0
this is what diagnostic programs are for. download & run memtest, let it run overnight. it will test your RAM to see if they are bad. also get checkitpro and run it. it will determine if your CPU/memory/chipset/HDD/ports (will need loopback plugs) are bad.
- Rep Power
- 18
Sounds like video lag... due to a insufficient video card. I'm guessing because you have said your computer is running 1gb of ram. To make sure run memtest like ttman said to verify that is/ is not your RAM.
If your RAM is good I would look at getting a new video card. More than likely your computer has integrated graphics and has the capability of upgrading to a AGP card. I'm only guessing during this part.
- Rep Power
- 0
do u use dial-up by any chance? or connect to real far away CS/S servers? sounds like network latency (laggggggggggggggg).
- RAM going dead?
- You may not post replies
- You may not edit your posts
Forum Rules
