Thread: Imediate Clutch Initiation?
    Default Imediate Clutch Initiation?
    I'm trying to fix the point at which my clutch initiates. Everything works, but in order for me to change gears, the pedal has to be all the way to the floor and the clutch initiates about 1/2 centimeter from the floor. My guess is the clutch slave cylinder, but does anyone have any thought?
    West palm beach
    have you tried bleeding it ?
    NO ADVERTISING
    -IA MANAGEMENT
    I don't know if the mechanic bled it when he swapped the engine, but ill definitely try it.
    Woodstock
    if you want to adjust the engagement point look at the clutch peddle and you should see a threaded rod with 2 12mm nuts on it...break the nuts lose and try spinning the rod out...you might have to grab the rod with channel lock or something like that...depends on how tight it is..cant remember if u spin it in or out...but thats how you change it
    So I found out today that i own a "Honda Silvia"...
    West palm beach
    Quote Originally Posted by DavidV
    do that first, then let us know...
    bleed clutch... simple as that
