Results 1 to 40 of 72
Thread: FS: D & B series misc parts LOOK INSIDE !!!
    Default FS: D & B series misc parts LOOK INSIDE !!!
    94+ cold air intake pipe! (fits only on stock GSR Intake manifold) never used/installed $SOLD
    99-00 ITR CRANK PULLEY $20
    LS THROTTLE BODY $5 (missing TPS sensor)
    B series Half Shaft $35
    2 = D SERIES THROTTLE BODY $5 EACH
    B SERIES STARTER CAME OFF a 96 integra $30
    B series speed sensor came off manual hydro tranny $SOLD
    D16Z6 INTAke manifold $40 SOLD to cybertaz75
    OBD2 d16z6 dizzy $25
    integra/accord/civic coil ignitor $15
    obd1 PO5 ECU (i belive a civic hatch cx?) $50
    LS throttle cable 94+ $25
    D16Z6 LONGBLOCK $50 (thats what i seen what d16z6 heads run for i think)
    2515313 block code under 170k miles.
    (Motor Locked UP) I really dont know how, Drove fine and everything. Decided to install a SK2 intake manifold on. and it just didn't turn over no more. And i've tried to turn the crank by hand, and it turns half way and stops and turns no more, but vice versa same thing and turns half way and no more also.. but i'ts up for grabbs!!
    Urethane Civic rear Lip 92-95 Civic hatchback!! dono what other it will fit but go figure(donno what style but i think CTR) $55 takes it!! brand new never installed/used
    Located in Kennesaw, GA
    Pm me if any interest for contact number
    Vick
    also - Looking for FULL SIZE RADIATOR FAN FOR 94+ INTEGRA (i'll take trades on anything posted or depending how much you asking)
    /Oo ___A___ oO\
    |=_/_______\_=|
    Cobb/Cherokee County
    d series throttle body come with tps??? i need one! pm me
    Unknown
    Default D16Z6 intake manifold
    Does the D16z6 intake manifold have everything with it?
    goodbye kitty
    hmm does that speed sensor fit a b18a?????
    Quote Originally Posted by cybertaz75
    i can make it complete for you if u want ..
    /Oo ___A___ oO\
    |=_/_______\_=|
    Quote Originally Posted by mewzer_b18
    if your using a hydro tranny then yes.. if your working with acable tranny then no..
    /Oo ___A___ oO\
    |=_/_______\_=|
    IA MEMBER jvillagran2000's Avatar
    EVERYWHERE!!!
    is the type R crank pulley the same as other B series pulleys or is it lighter?
    Quote Originally Posted by jvillagran2000
    i have no idea, it's just that i didnt have the right belts to run my alternator/ps/ac so i used my LS crank pulley and took out the itr pully iono same thing i guess.. but theres prolly something to do with the harmonic balance though i believe .. correct me if i'm wrong ne1 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    Unknown
    Quote Originally Posted by YouKnowIt
    I'll take the complete intake with everything that goes with it. When can i pick it up?
    pmd
    /Oo ___A___ oO\
    |=_/_______\_=|
    Unknown
    pmd
    pmd back
    looking for full size radiator fan for 94+ integra .. if anyone has one.. i'll take trades on anything that your interested in.. and or i'll buy if price is right..
    /Oo ___A___ oO\
    |=_/_______\_=|
    Jonesboro/Stockbridge
    i think ur block has a bent rod in one of the cylinders.
    Quote Originally Posted by JDM onlyy
    heres the thing though, I drove it Fine from my backyard to the front, thats no more then 1min.. And went ahead and replaced my IM for a aftermarket one and that was it.. plugged everything to where it soppose to be.. And
    che che che che che che che = starting up car
    che che = sounds like low on battery
    cheeeeee = starter only clicks now
    aftermath just to make sure everything was working properly. I jumped the battery, took off starter and make sure it was working properly i've tested it with my cable jump start box..
    cheeeee = same outcome
    Went and turned the crank by hand with the 19mm socket i think and only turns half way here 2 there only.. iono how I could possibly broke the motor from just replacing the IM hahaha but it's fixed now though replaced the motor .. thanks to boostedb16
    /Oo ___A___ oO\
    |=_/_______\_=|
    The Gradies... KillTheCrow's Avatar
    Hmm. If I get hired tomorrow I so want that motor!
    Quote Originally Posted by KillTheCrow
    8D lmk ..
    /Oo ___A___ oO\
    |=_/_______\_=|
    http://s188.photobuc
    powder springs GA
    how much for the lip text or call me at 678 663 9868
    Quote Originally Posted by lil moso
    calling u know
    left you a voice message hombre
    /Oo ___A___ oO\
    |=_/_______\_=|
    building the new ef revized_DX's Avatar
    northeast ga
    bump for good seller!
    Quote Originally Posted by revized_DX
    wats going on mann .. hows the ecu running!
    /Oo ___A___ oO\
    |=_/_______\_=|
    northeast ga
    man i did great! i have been running it since i got it. just got lucky yesterday and got a chipped pm6 /no fuel cut off so im running that one now.
    kool .. well u got pm and vtec solinoid however u spell it is still there etc holla
    Bump
    /Oo ___A___ oO\
    |=_/_______\_=|
    /Oo ___A___ oO\
    |=_/_______\_=|
    /Oo ___A___ oO\
    |=_/_______\_=|
    jdm josh ground_shaki's Avatar
    very far south
    whats the deal on the starter and where you located
    very far south
    my bad Kennesaw ga i see it now
    /Oo ___A___ oO\
    |=_/_______\_=|
    your moms house
    was the less on the lip pm me plz!!!!
    (((((No more 4 door))))))
    your moms house
    pm me with the price
    your moms house
    pm me with the price n ur number want ta bak lip tanxz !!!!
    Quote Originally Posted by civic gsr
    pmd
    /Oo ___A___ oO\
    |=_/_______\_=|
    /Oo ___A___ oO\
    |=_/_______\_=|
    /Oo ___A___ oO\
    |=_/_______\_=|
    All Motor EK N/A EK's Avatar
    On IA.com
    you still have the aftermarket gsr intake. if so, hit me up 404 421 7004. i can pick up friday whenever.
    Quote Originally Posted by EF Allmotor
    if your talking about the 1 pc air intake pipe, then yes i still have it lmk something
    vick
    /Oo ___A___ oO\
    |=_/_______\_=|
    On IA.com
    vick
    Yep the aluminum piping...
    oH My BudDa
    if you still have the DC stock air box. PM me your location. Will get it this weekend.
    Quote Originally Posted by takume
    tossed it in the garbage bro was taking up space
    bump everything else still up for grabs
    /Oo ___A___ oO\
    |=_/_______\_=|
    tink tink btldzc's Avatar
    COG
    Ill buy the lips for 50$ LMK
    IN LOVING MEMORY OF GAI
    SEE YOU WHEN I GET THERE BOIE!
    3/8/75 TO 4/18/05
    COG
    I retract my offer...i thought it was the front
    3/8/75 TO 4/18/05
