Results 1 to 5 of 5
Thread: Cheap Cheap 4age Parts & mr2 1986-1988 Must go!
    IA Member Nightwalker's Avatar
    Georgia ,Norcross
    Exclamation Cheap Cheap 4age Parts & mr2 1986-1988 Must go!
    Cheap- Cheap- Mr2 parts from the 1986-1988 model mr2s.
    Im leaving for the Army in the middle of May and I need these parts Gone ASAP!
    All parts have been inspected for leaks cracks and have been tested with a volt meter according to the BGB.
    All parts are used from a parts car.
    I will clean all parts be for they are shipped out and shipping will be added once we come to an agreement on price.
    I am open to offers and willing to make bundles for a good price.
    Nothing is Over 40$
    http://s607.photobucket.com/albums/...87/Mr2%20PArts/Contact Info: [email protected]
    [email protected]
    Aim & Yahoo messenger – Nightwalker2687
    Phone: 678-768-8967
    For Sale :
    ·1988 side skirts – 15$
    ·Radiator and fans – 30$
    ·Front Oem Strut Bar – 10
    ·Gold Valve Covers and valley cover - 30$
    ·Used MAF – 20$
    ·Manual trans ECU – 35$
    ·OEM Intake Manifold with sensors – 20$
    ·4age Head- 30$
    ·4age 7- rib Block – 30$
    ·4age Crank Shaft - 20$
    ·Fuel rail- 5$
    ·4age pistons and rods from 7-rib block- 10$ (each)
    ·Oem Cam Shafts and gearz – 15$
    ·A/c compressor and misc – 35$
    ·Engine mounts – 5$
    ·Cruise control vacuum – 5$
    ·Heater valve -10$
    ·1988 - Throttle Body/ w TPS – 25$
    ·Ignition switch – 5$
    ·Cruse control Switch- 5$
    ·Brake light switch- 5$
    ·Clutch slave – 5$
    ·Water pump pulley – Free
    ·Horn- Free
    ·Thermostat cluster/w Sensors – 20$
    ·Two 1986 rear calipers and brackets -20$
    ·1986 Brake Master cylinder – 5$
    ·Oil pump Strainer -5$
    ·Oil Dipstick – 5$
    ·Fuel pump gauge-5$
    ·Two1988 Fuel injectors – 10$
    ·1986 Shift assembly -5$
    ·Ignition Coil - 10$
    ·Prothane steering rack bushings NEW from Twosrus – 10$
    ·Main Wiring with fuse box – 25$
    ·Two new Cam seals – Free
    ·4age Timing cover – 10$
    · Rear Glass from an 1988 – 20$
    RickEy LEe
    What year is the main wire harness and fuse box too?
    Georgia ,Norcross
    Quote Originally Posted by Anarchy187
    The harness is from an 87 mr2.
    RickEy LEe
    Unknown
    yo ill take poly bushing steering... cam seals... and is the fuel pump gauge the gas gauge ....
    Capt. EverGreen
    kangarooster meadows
    do you have any interior parts need the center console for an 86 and the side skirts also
