Results 1 to 5 of 5
Thread: gsr crank in a ls block?
    BOOSTED GSR/HYBRID
    ON THE TRACK
    Default gsr crank in a ls block?
    cant you use a gsr crank in a ls block with ls rods? i put it in and i cant see the difference..unless its not truely a gsr crank
    BOOSTED GSR/HYBRID
    ON THE TRACK
    Default why do i keep spinnig bearings?
    and dont tell me lack of oil because i dont do that shit or its a dent in my oil pan because i dont have one
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    english?
    ls rod shouldnt fit on a gsr crank just a b16.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    gsr is 87 mm so the piston would come up shy at the top. b16 is 77mm so it would really be shy at top and ls and b20 is 89mm. and ls rods will fit on gsr but as i said they all come up short because the throw on the cranks are different so the longer the throw the shorter the rod, the shorter the throw the longer the rod.
