Results 1 to 19 of 19
Thread: Have an Oil Leak, need help diagnosing.
    Gwinnett-Grayson
    Default Have an Oil Leak, need help diagnosing.
    so i noticed a few minutes ago that i have an oil leak. its not where near the oil pan and i cant see anything from the top. i look to the left of it and i see a dried up build up of oil. im assuming around the clutch? forgive my ignorance. can anyone help me figure this out. sorry for the lack of info.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    i'm a got dang wallaby!!
    yes lack of info is correct. sigh
    check from the top down davison...
    valve cover gasket
    distributor
    manifolds
    pcv
    blowby hoses
    *best thing to do is actually spend time CLEANING your engine bay then check it every day or so its ALOT easier to see things that way*
    also, oil filter/housing
    Gwinnett-Grayson
    yeah, i know. sorry about the lack of info, its just that im not too good with engines and what not so i dont really know what to expect or look for. i looked to see where it was dripping from and im ASSUMING its near the clutch, not 100% correct. its on more of the middle/passenger side of the car.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Southside Ridin HATCH
    Its not coming from the CLUTCH!!
    do what the OP said and pressure wash the motor, check in a few days!
    ACTUALLY take a pic and post up exactly what your talkin bout!
    o and when you pressure wash it or hose wash , cover the dizzy and alt with plastic bag or somethin!
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    cam plug seal, or dizzy seal, will leak and run down the motor and tranny seperation line where they are bolted together and when dirt an debris collect on it it builds up like this.
    take a pic of where you are talking about. but if its coming from your 'clutch' then its your rear main oil seal. you change it when you do your clutch normally cuz the trans has to come off, so in most cases its a preventative maintenance. since you said you are rebuilding your engine soon, replace your clutch and the rear main oil seal.
    but it could also be your cam plug...is the oil leaking on the ground? also i have a write up on detailing the engine and its not necessary to cover the dizzy cover or alternator, if u want the write up hit me up and ill find it for you
    turbos
    most likely honda leaks
    distributor o-ring
    cam plug (seal)
    Valve cover
    Oilpan gasket
    in your case im betting on the o-ring or cam seal
    wipe your fingers on the underside of the dizzy, if the o-ring is bad your hand will be dirty
    cam seal is behind the vtach solinoid on a b-series
    TOO BIG
    i drive slow im_hung's Avatar
    location, location
    could be rear main. take the clutch inspection cover off and check...
    Canton, GA
    yep...you got an oil leak
    time for a new engine
    Southside
    any updates
    hustler ksniperfox's Avatar
    lawrenceville
    Quote Originally Posted by seanrg1116
    distributor o-ring
    cam plug (seal)
    Valve cover
    Oilpan gasket
    this man speaks troof!
    Gwinnett-Grayson
    thanks guys. ill be looking into it probably at some point this weekend. i am probably going to jsut rebuild my engine, im pretty much deciding on that.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    if ur decided on rebuilding..then why you gota thread on where to get another engine?
    turbos
    ^^^^^^lol
    I noticed that to.
    do you even know what kind of compression numbers your motor has. before you go rebuilding it
    TOO BIG
    2.0vtec
    Snellville, GA
    if its a honda then it could only be leaking from valve cover, vtec solenoid, dist. oring, rear main seal, oil pan, seals at the front of the engine(including balance shaft), pcv canister at the back of the block and oil filter housing. you will have to trace the residue. if the residue is too much, then clean, drive and try to retrace. pretty much most engines will work like that. you have the front(timing belt side), rear(tranny side), top(valve covers, misc) and backside(oil coolers or filter housings). all have seals. some are easy to get to, but front and rear are the most time consuming. good luck.
    Mahdavi Motorsports
    770-923-1550
    04 S2000 Turbo
    NDRA turbo 6 champions
    Nations fastest auto mkIII Supra
    Gwinnett-Grayson
    cause i thought about it and i need something to role around so im just going to buy a used and rebuild it. while i have my car to drive.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Gwinnett-Grayson
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    LaFayette Ga.
    vancem3m3 has some blocks and stuff. ls and gsr.
    Apr 2009
    Villa Rica
    im kinda having the same problem with my 94 civic ex....pulled out the factory motor due to bottom end knock....replaced it with the same d16z6 motor but with only 80k miles....since its been done for only 2 weeks ive been trying to trace this oil leak that im having....its not coming from the valve cover, distributer cap, dizzy or vtec solenoid....im really just hoping that its the oil filter seal because im not sure if the mechanic changed it out or not because the dummy didnt tighten down my oil plug on the pan....i dont think its coming from the oil pan either....when im under the car you can see where the oil is dripping a little from around the tranny where it bolts up to the motor....im not sure if theres a rear main seal or not....will someone get back with me and let me know what it could be before i start paying out alot of money and let me know what i should look for....i did clean the motor up but it started dripping oil again and its hard to trace when im not sure exactly what im looking for.... thanks guys
