Results 1 to 23 of 23
Thread: HELP!!! My car is going HAYWIRE!
    Default HELP!!! My car is going HAYWIRE!
    ok so i have a serious issue. My car will not stay on that long after i jump it for a looong time. It has a brand new alternator and a brand new starter. After it is jumped it is fine then i start to drive it and a good 5 minutes later the speedometer lights start to dim and the headunit cuts on and off and the headlights start to flicker. When i noticed that start to happen i pulled into the garage and it just cut off. Jumped it again and drove for a while to see if its ok, then after a good trip around the neighborhood it started doing it again. parked in the garage let it idle for 5 mins, cut it off, and tried to start again but no start. It did have an electrical issue about a couple weeks ago. The tailight wires were burnt from putting a high fuse into the fuse box and the wires were fried but we got that fixed. Could it be a bad ground? help IA.
    btw, the car is a 96 civic with b20b. also the alternator light wont even come on when key is half way turned
    Certified Gearhead schia89's Avatar
    Oct 2008
    how bout your battery?
    West palm beach
    crank it up and pull the negetive side battery cable off while its running, if it dies the alternator is bad. if you rode around with a dead battery you probly killed the alternator. If its not that look at all your grounds and check the battery again.
    NO ADVERTISING
    -IA MANAGEMENT
    Yo face! SUBY_RUE's Avatar
    in the land of ozz
    Your running off the battery, Check the alt you just put on, and make sure the wireing is right...
    For one hell of a life
    I got my girl got my family
    For a hell of a time
    HELLYEAH!
    Make sure the Alternator is putting out voltage, Use a Volt meter to see, Just cause it's new don't mean its good, Check at the Alternator and also at the Batt. If it shows 14 volts at the Alternator but not 14 at the Batt while running there is a break in the Wiring..
    Hope that helps!!
    hustler ksniperfox's Avatar
    lawrenceville
    Quote Originally Posted by SUBY_RUE
    x2.
    take it back to whoever put the alternator on, or a different shop to get a 2nd and honest opinion. or if you did it, re check everything yourself. sounds like your alternator still isnt effective.
    Southside Ridin HATCH
    Yes you have a short some place, or a ground not on, also alternator!
    I hade this problem long time ago... found out it wa TWO wires touching eachother!!
    Gl man
    Quote Originally Posted by ksniperfox
    x2.
    im sure its put on right, ill re-check everything. but a short could be causing my alternator to fuck up? and not work? i mean, the alternator light doesnt even come on when the key is half way turned
    Quote Originally Posted by Black4DrEK
    Gl man
    any input on where i should be looking? where did you find yours, and how long did it take you to find it?
    LAWRENCEVILLE
    make sure you check all the fuses! i had a similar issue and swap the alternator. and it turned out to just be a poped fuse!
    Hella stock member!
    ok so a miracle just happend. i just went outside to check the volts and jumped the car and there was a really loud screach coming from driverside bay area. idk wth it is. but i do know that my alternator belt is hitting the timing belt cover and it broke a hole in it so it could spin. its still spinning good but just cut the timing belt cover up. I can now take the negative terminal off and the car will still be on. but when i turn off the car and turn it half way again the battery charging light is still not on?? and when i start the car agian that screech is still there.. what could that screech be? it is very loud. i will make a video of it if i can.
    here are the volts.
    1 - 9.87 with the engine off
    2 - 13.91 warming up
    3 - 13.15 with engine warmed up headlights on and ac blasted
    IA Member greengolfbal's Avatar
    sounds crazy, but are you sure you put the belt back on correctly?? Make sure it is lined up in the center of all of your pulleys
    make sure the belt it TIGHT!!!
    gone old school C-loS109's Avatar
    somewhere
    had this problem... took my battery to get it tested. it came out good. tested my alternator and it was good. tested everything possible and everything came out good. so i was going to change everything so i changed my battery first. and now i dont have the problem.
    =EJ-EG SQUAD SUPPORTER=
    2000 HONDA CIVIC - SOLD
    1966 MUSTANG COUPE - TRADED
    1989 FOXBODY MUSTANG - DD
    Quote Originally Posted by k20ej8
    here are the volts.
    It's charging but the Batt is bad.. The noise could be the belt, make sure its tight and not hitting anything..
    Quote Originally Posted by C-loS109
    i heard this is a common problem for 96-00 civics. and i just got this battery in january. i guess i gotta get a new one.
    Quote Originally Posted by 1civic
    yea i think so but the car wont start at all anymore. even after i jump it. and i use the voltemeter on the battery and its 12.47 when the car is off.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    see if your alt belt is too loose and not charging cause the more stuff you have on the more it pulls on the engine. if its slaping around thats what broke your cover. its just not loose enough to tell without touching it.
    i drive slow im_hung's Avatar
    location, location
    It could be your ELD. I would check that last, but they do go bad from time to time.
    engine off it should be around 12 volts... make sure that battery is good and your connections are top notch.... check the eld like mike said they do an can go bad i had that problem a few times but not likely
    LaFayette Ga.
    i think the screach is a loose belt! not letting in a complete charge.
    battery is good, but low on charge. i will check the eld prolly get a new one at the junk yard with a 80A battery fuse that popped also.
    Quote Originally Posted by turbob20
    it was on pretty tite.
