Results 1 to 14 of 14
Thread: Identify this noise (video attached)
    1010011010 Atlblkz06's Avatar
    Hell
    Default Identify this noise (video attached)
    I figured I'd post this here to help someone out. It sounds like the piston but I really have no idea.
    Please post if you think you know what this is. LINK:
    http://www.youtube.com/watch?v=bjuGOPSvE5o
    C7 On_Her_Face's Avatar
    Duluth
    I'll tell you exactly what it is. The cats got too hot, overheated, sucked back up a peice of metal into cylinder 1 and is chewing the piston, head, and scaring the block.
    Alpharetta, Ga
    its was built by vengence.... thats your first problem. second... save your pennys boy that a rebuild!!!
    but really. sounds like bottom end. to fast to be topend.... but then again its a video...
    The G Spot Hero
    Hell
    Lingenfelter, not Vengeance lol
    I'll relay the info, thanks!
    sounds like spun rod bearing
    /Oo ___A___ oO\
    |=_/_______\_=|
    Sounds like Lifters to me...
    Alpharetta, Ga
    Quote Originally Posted by 1civic
    pssttt its cam in block...
    The G Spot Hero
    I thought it was muffler bearing who knows that VID is hard to tell,maybe broke push rod, sounds more like a knock rev it up to about 9k rpms and do a vid and let us all hear it again.
    Alpharetta, Ga
    ^ lol 9k with a pushrod motor lol...
    The G Spot Hero
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    How many miles does it have?
    Hell
    Fresh info - it happened after a 190mph run.
    No clue on the mileage. I've never even seen the car.
    9kRPM? This isn't a rotary! An LS7 will hit 7k stock but this is a 454 and with an issue this big it'll definitely blow up. Wait...
    Alpharetta, Ga
    whatever it is. the motor needs to be removed and torn down for a rebuild. simple as that. driving it/running it is only going to make it worse. and more expensive, because you might throw a rod through the block which means youll need rods and block. if not already. so basicly pull it quick and get it over with. might just need some machine work on the crank and some bearings. vs.... crank block rods pistons cam valvetrain... you know a crate motor.
    The G Spot Hero
    D0 W3RK RedEj8's Avatar
    Macon
    Sounds like a lifter or rod knock to me too.. Make sure its not a lifter before you just tear it down.
    G-net
    Bitch sounds like cummins. DirtyMechanic said it perfect though
    One Big Ass Mistake America
