Thread: Write a Java program for money/reps
    roflcopter V-Spec II
    Norcross
    Default Write a Java program for money/reps
    Alright I need a simple java program (Intro to Java) written ASAP. Paypal and reps are in order.
    Question:
    "Find the calss StringBuffer in java API, and find appropriate methods in the class to do the following:
    Finding all matches of a substring in a given string, the substring and the string must be inputted from the keyboard.
    The output should be the starting index numbers of the matches. For example, if the substring is "ab" and the string is "xabbnabz" then the output is 1 and 5, the indices of the two matches from left."
    I KNOW we have some java monsters in our midsts.
    Gwinnett-Grayson
    fuuuuuuuuuuck that.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Norcross
    Quote Originally Posted by blacknightteg
    fuuuuuuuuuuck that.
    x2. It'd be easy for someone who knows the ins and outs though.
    Gwinnett-Grayson
    true lol.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Douchebag Ed's Avatar
    Smyrna, GA
    man 3 years ago when i was taking java hardcore i could do it but i forgot it all. if you cant get it done by tonight i'll give it a try.
    Norcross
    Quote Originally Posted by Ed
    Need it by 1:45 lolz...
    Smyrna, GA
    ah. good luck.
    1010011010 Atlblkz06's Avatar
    Hell
    I forgot java but... can you input the string as an array, loop through blocks of letters to find the query?
    say the input block is "bobwehadababyitsaboy" (length 20)
    You are searching for "had".
    had = 3 length.
    make the program loop through the array from 1 to 20-3.
    Select 3 letters and see if those 3 match "had".
    Record the positions where you get a match and your output will be "5"
    Hope that helps.
    if you woulda posted up earlier it would be no problem. I'll see what I can do
    - IA Mgmt
    Hell
    Is it done yet fcman? Tick tock! lol
    Norcross
    Got it gentlemen, thanks anyway. If any of you were working on it, here's one of the things it could look like:
    import javax.swing.JOptionPane;
    public class nurvspecii {
    public static void main(String args[]) {
    String subString = JOptionPane.showInputDialog(null, "Sub String: ");
    String mainString = JOptionPane.showInputDialog(null, "Main String: ");
    StringBuffer x = new StringBuffer(mainString);
    for(int i=0; i<=mainString.length()-subString.length(); i++) {
    String temp = x.substring(i,(i+subString.length()));
    if (temp.equals(subString)) {
    JOptionPane.showMessageDialog(null, i);
    Ghost AirMax95's Avatar
    On a Plane
    Fuuuckkkkkk Java......although I am relearning it, lol.
    VB anyone? lol
