Results 1 to 34 of 34
Thread: S14 partout, interior, body, etc.
    Default S14 partout, interior, body, etc.
    Some prices are negotiable, best means of contacting me would be through calling or texting me at 404-414-0547. If I do not answer leave me a voicemail, I will respond. I will consider multiple part discounts. I have had most of these parts for a while and tried my best to list them as honestly as possible. Parts are located in Snellville. Basically I have too much stuff and now it needs to go! Here goes…
    1. 95 240SX drivers side headlight, inner tabs are broken, only mounting tabs that remain are the ones that mount to the fender $10
    2. S14 240SX 95-98 passenger side mirror $25
    3. S14 240SX 95-98 passenger side mirror (one shown on the door below) $25
    4. S14 240SX 95-98 windshield washer reservoir, pump etc $10 each- I have 2 of them
    5. S14 240SX 95-98 gauge cluster bezel $20 each
    6. S14 240SX 95-98 fuse box cover $5
    7. 240SX stock front calipers, only reason why they were removed is to do a brake upgrade, they worked great prior to this. I just have them sitting in storage with no use $10 each- I have 4 of them(2 pairs)
    8. S14 240SX 95-98 fender liner- I believe that this is the passenger side liner $5
    9. S14 240SX 95-98 rear speaker panel $30
    10. S14 240SX 95-98 woodgrain dash accents- would be great for those with a cracked radio trim, paint it whatever color you like and attach it to the stock radio trim. Also comes with a drivers side power window control cover as well. $20
    11. Piping pro SR aluminum intake, I was told that it looks like it was made for a top mount turbo setup, it can also be used with a stock mounted turbo setup but it required an extension…I bought it off of zilvia through a group buy. Brand new, never used $20
    12. S14 240SX 95-98 AC fan $20
    13. S14 240SX 95-98 windshield wiper arms $5 each
    14. S14 240SX 95-98 driver side headlight internals you can use it to try an HID projector retro fitting $5
    15. S14 240SX 95-98 clutch line $20 (other 5 speed parts already sold)
    16. S14 240SX 95-98 rear side windows tinted 35%- comes with the rubber seals as well $30 each
    17. 240SX master cylinder (booster already sold) was removed from a car with around 185,000 miles, worked great until the end $20
    18. Power steering high pressure lines, had no leaks, just messy from disconnecting hoses etc. Was removed from a 95 240SX $30
    19. S14 240SX 95-98 front sway bar, comes with endlinks too. $20
    20. S14 240SX 95-98 trunk trim piece $15
    21. S14 240SX 95-98 strut mounts $15
    22. These ECM’s were removed from an automatic 1995 S14. I know that one is the ECU, the other 2, I am not sure of. I think that one is the keyless entry module and the other is something for the automatic transmission. $10 for the ECU, $5 each for the others.
    d24
    I NEED THE AC CONTROL AND THE DRIVER SIDE DOOR BELT MOLDING,,,BLACK PLASTIC PIECE GOES ACROSS FROM THE OUTSIDE DOOR,,,LET ME KNOW,,THANX
    Senior Member famous_atticus's Avatar
    Southside
    I am interested in a lot of the parts you have. i have cash in hand and would like to meet up tomorrow. give me a call at 404 766 8668 anytime thanks.
    You're cool.
    -RG
    IA Member lama08's Avatar
    i need dat driver side door panel and of i have the stock center pieces where the oem radio goes. pm me if u got it and im interested in those fenders
    If you try calling and dont get me, leave me a voicemail. I will return your call. I am available today at around 6, so if there is anything that you are interested in let me know so that I can get them out and avoid searching for stuff on multiple occasions. I have several persons who should be meeting me today also, for the most part everything is on a first come first serve basis.
    Oct 2008
    wow!
    good luck selling all this stuff man
    Quote Originally Posted by kcdrift
    wow!
    Thanks, I just want to clear some space. I have too much stuff!
    Thread has been updated, more stuff added, more stuff sold!
    Unknown
    how much do you want for the security button shipped to 74021???
    Default rear spoiler
    i need the rear spoiler can i pic it up if so pm me.
    Where are you located? Would like the front spindle.
    updated!
    Quote Originally Posted by hdragster
    security button? can you be more specific please.
    Quote Originally Posted by rwdawg2
    sorry, front spindles already gone
    Quote Originally Posted by josh price
    rear spoiler also sold
    Unknown
    this
    that will go with the ac trim, not parting out the security button from the trim
    o=(O_o)=o ChRiS's Avatar
    Check your inbox
    replied
    up up up
    Would like the :
    Door (passanger)
    Fender
    and trunk cable.
    Are they still avalible?
    More parts sold today, lots more left!
    Quote Originally Posted by PITCH
    Would like the :
    Door (passanger)
    Fender
    and trunk cable.
    All parts listed are still available, I update the thread whenever I sell something. Give me a call...
    northside
    still got that bummper?
    yes i do!
    Certified Gearhead Blaze_Cunnings's Avatar
    Hey do you have the weather strip for the entire driver side door, Im talking about from top to bottom. Also still got the rear interior panels?
    BUMP, I sent replies via PM to the inquiries...
    more parts sold, more left!
    BUMP!
    BUMP!
    bump, updated the list!
    Dalton, Ga
    i need cross member if you wanna sell txt or call 706-876-8352
    turbo lagg = the few seconds where the other guy thinks he is winning!
    drives a trycicle
    newnan
    u got s14 driver side master window switch?
    how much for clutch lines shipped to 36509 pm me
