Results 1 to 3 of 3
Thread: B13 FOR SALE!!!
    slide slide olivertwist's Avatar
    doraville
    Default B13 FOR SALE!!!
    1993 Nissan Sentra SER 2000
    1993 Nissan Sentra 5speed SER asking price is $2000
    VIN: 1N4GB32A1PC737044
    The car a stock sr20de not a swap has 190xxxx on it. It has been kept up to date on all that part has a very good running A/C and Heating unit. The stereo and speakers or all new and comes with the car. I have personally done all the maintenance to the car such as:
    • Oil change 10w40
    • Transmission fluid changed
    • Power steering fluid changed
    • It's a very clean car; just needs a new carpet and a new driver the car is worth a little more now with all the new parts that I have replaced
    I bought the car on
    September 12, 2008
    I was the third owner of the car. It came with a new water pump, belts, and new left axel and steering wheel.
    On December 19, 2008
    I replaced all the injectors because one did not spray. I decided to change them all at the same time and also change the spark plug and distributor, rotor and ignition wires in the car.
    January 2009
    I installed a new OEM alternator and OEM Starter because it had trouble starting in the winter weather.
    February 22, 2009
    I just recently installed a new Exedy clutch and a stock resurfaced pressure plate from The Clutch Man in Lawrenceville, GA.
    April 2009
    I installed a new tie rod.
    The only issue with the car is that it needs a new gauge cluster and carpet and probably tires. :P The body is very good however, there are two small dents and a few scratches on it.
    The engine is very strong though and it never gave me a problem.
    I’ve used the car mostly for work and have not taken any trips in it.
    The car is located in Norcross, GA. I can be contacted at 770 598 8863
    I need new tires
    Pics?
    Barrett Parkway, GA
    ibtl
