Results 1 to 40 of 47
Thread: misfire on all six cylinders on a 2003 accord v6
    firren muh laaazahhh stephanie's Avatar
    Southside
    Default misfire on all six cylinders on a 2003 accord v6
    what the hell is wrong with it....what would make that happen. me and my friend are going to try and fix it. but i think it is going to have to be taken to a shop.......any suggestions? please!!!!!!
    last weekend we figured out the passenger side headlight was out, and you have to remove the whole friggin battery to change it.
    Southside Ridin HATCH
    Spark plug wires. (coil pack) if it has one... Plugs.. Dizzy
    Southside
    thanks...she did go get the code pulled earlier.
    just trying to see where to go next with it.
    ^ I would go with Wires, plugs, ect...
    Start small then work your way up!!
    Southside
    its all six cylinders though...thats the fucked up part.
    Kennesaw, GA
    I would start with a trip to Honda
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Does it have any Oil leak in the Head? can you see oil all over the Valve cover gasket?
    did u have anything done b4 it started acting up?
    Quote Originally Posted by hotshot
    ^ and spend a ASS LOAD of money!!
    Rome,Ga
    crankshaft sensor
    Quote Originally Posted by Black4DrEK
    throwing parts at it due to lack of diagnostic skills or unqualified shop could cost more. kinda like a gamble either way unless a friend with skills works on it.
    does it miss when it hot or cold or both
    take plugs out and see if they are Covered with OIL...
    Quote Originally Posted by terrytowe22
    crankshaft sensor
    explain your theory if u dnt mind. and how would one go about testing to see if thats what the prob is.
    not really all that true. my truck was at the dealership for 3 day last week. its also going back for 3 days this week. thats all they are doing is throwing parts at it.
    Rome,Ga
    well on my buddy jetta vr6 it would run like crap it would cut out acting as if it was misfireing so we changed the plugs nothing happen did a whole tune up still did it so we change the crankshaft sensor in it ran perfect
    but it was just a seggestion
    do you know for sure that it is misfiring>?
    ^ yes she said they had the codes ran allready
    Rome,Ga
    also to test it take it out in see if the little circle in the middle of the sensor, check to see if the magnet is not gone.
    WTF?!! And ur paying for it?
    Southside
    thanks. i will talk with her tomorrow. maybey find out more info. i need to go to bed early i feel like crap! but im willing to drop about anything to help her.
    and she needs some daylight to look at the car
    Southside
    i really appreciate the help too!!!!
    Rome,Ga
    oh when we ran the codes on the jetta it said randomly misfiring.
    Kennesaw, GA
    Some people dont know any better
    OF*C
    ^^ let us know something
    Kennesaw, GA
    i already gave my advice
    OF*C
    i drive slow im_hung's Avatar
    location, location
    03 v6 accords have an issue with the egr port getting clogged.
    i would check the egr port...
    Stang Mod slostang's Avatar
    Southside
    Quote Originally Posted by mikegsr
    i was about to say the same thing.
    but that will not make it misfire!!!
    tune up, ecm,something in the fuel etc
    Quote Originally Posted by slovic
    Not the problem:":":":":"
    location, location
    i retract my statement. (i would check/clean the egr port anyway )
    update your pcm software. should cost about $85 at your local Honda dealership
    If he has no egr codes don't waste the time , its not a issue at this time.
    JDM TYTE AnthonyF's Avatar
    Do you just say random shit?
    take it to a shop. It sounds like an easy fix with the proper computer.
    -Ant.
    The Carbon Fibered R6
    awwwwwwwwww
    -Ant.
    ^^ No jackASS
    what i said could possibly be the PROBLEM!!!
    It could easy be the Coil pack/ plugs!!
    ^^ No jackASS
    think he is talking about this post!
    \m/>_<\m/ dorin48's Avatar
    Canton
    This thread is full of fail. lol
    The only things that could , under normal circumstances, cause a random multimple cylinder mis-fire Code P0300 is Crankshaft position sensor, Camshaft position sensor, or ignition control module. Possibly the coil pack but only if its for all six cylinders. Not plugs/wires or anything that is dedicated to a single cylinder. The code means mis-fires on multiple cylinders not intermittent mis-fires on a single cylinder.
    Senior Member ej6kidd's Avatar
    dallas
    I HAD BOUGHT A MAZDA 6 WITH THE SAME CODE AND ALL IT NEEDED WAS THE SPARK PLUGS AND COIL.
    Quote Originally Posted by dorin48
    Southside
    seems like it was some sort of computer malfunction. the mechanic pulled the code and she told me it spit out a bunch of codes. he test drove the car and said it "ran like a scalded ape"
    and thanks again everyone!
    ^ good to know
    Quote Originally Posted by b18vtec92
    ^axactly
    Im not a Dumb ass, my post wasnt stupid!
