Thread: srs problem
    earth ????
    Default srs problem
    ok today i went to hpc "honda parts connection and, got a dash for my delsol w/o the pass air bag. i installed it my srs light came on i know it would so i though i could just reset it and, it would be all good my srs sytem the light comes back on sooo what srs system box do i need for my delsol so my srs light will cut off after 5 seconds after the car started up ??? anyhelp would be great ! thx
    earth ????
    thanks guys......
    ruffhuhrass DriVaH's Avatar
    the block(gully side)
    i dont know wat box u need but i found this http://www.honda-tech.com/showthread.php?t=1760922 . hope it helps
    my attitude is celibate, I DON'T GIVE A FUCK!!!!
    gully side movement.
    from slavery to president!
    LAWRENCEVILLE
    if your had a passenger side airbag, and you installed a dash with out a airbag? the srs unit is looking for the airbag that is not there. i dont know how you can fix this problem besides putting the correct dash back in. or i dont know if this will work. get the srs unit from the older car that only has the sterring wheel airbag.
    Hella stock member!
    Get the SRS unit from the other car..
    barrow county
    take the light bulb out and its fix
    Scottish Scotsman's Avatar
    on the road to recovery
    just overlook the light , i put an aftermarket steering wheel in my EG and it stayed on 24-7 , i knew why it was on ,it is not a CEL , so i wouldnt sweat it(unless you have OCD)then take out said bulb
    earth ????
    Quote Originally Posted by eclipse_boy
    wrong. if i hit some one my s/wheel will not deploy.
    earth ????
    ocd overdrive ahhhh lol
